Cisco 3000 groups and IAS
Hi there
I am trying to get people authenticated into the Cisco 3000 groups when connnecting using an IAS RADIUS server. It seems to only authenticate into the Base Group.
I know the answer is to send attibutes using the Remote Access Policy - but which ones?
Re: Cisco 3000 groups and IAS
You can make use of the following document
Configuring the Cisco VPN 3000 Concentrator with MS RADIUS
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a0080094700.shtml
I figured it out already. You put the group in under the attribute 'Class' using the syntax OU=groupname;
The document you linked doesn't actually have anything about the groups. But thanks anyway.
168
