Cisco PIX 501 does not develop VPN after DSL disconnetion and rebuilding
We have the problem that our Cisco PIX 501 6.3(4) does not develop the VPN tunnel any longer, after the Provider disconnect the DSL line after 24 hours and rebuild it. Afterwards the tunnel seems to stand however it gives no more connections. Only after restart of the PIX or pulling and putting the cable of VPN the tunnel rebuilds. Otherwise everything runs perfectly.
The PIX develops a connection to a Cisco Concentrator 3002.
Here is our configuration:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
interface eth0 auto
enable password XXXXX
passwd XXXXX
hostname PIX4322
domain-name network.net
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.50.16.41 255.255.255.248
ip audit info action alarm
ip audit attack action alarm
pdm location 10.50.0.0 255.255.0.0 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
route outside 10.50.0.0 255.255.0.0 X.X.X.X 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
management-access inside
telnet 10.50.0.0 255.255.0.0 inside
floodguard enable
telnet timeout 5
ssh timeout 5
dhcpd address 10.50.16.42-10.50.16.46 inside
dhcpd dns 10.50.20.102 10.50.20.103
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain network.net
dhcpd auto_config outside
dhcpd enable inside
vpnclient vpngroup VPNLAN password xxxxxxxxxxxxxxxx
vpnclient username PIX999 password xxxxxxxxxxxxxxxxxx
vpnclient server X.X.X.X
vpnclient mode network-extension-mode
vpnclient enable
Does anyone have a idea? Thank you.
Ludwig
Silver
Re: Cisco PIX 501 does not develop VPN after DSL disconnetion an
Ludwig,
This problem is most likly due to to the IPSec tunnel remaing active as there are no keepalives being sent. So the link fails but each VPN device is unaware of the failure.
There is a command `isakmp keepalive' which enables this feature in client and L2L vpn's.
I'm not sure if this will work with the PIX when configured for ezvpn, but its worth a try.
If not then there are options on the concentrator to enable this feature, it may solve your problem here.
Andy
Hello Andy,
thank you for your information. Apparently works the function "isakmp alive" with Easy VPN, but it did not solve my problem. The VPN tunnel is nevertheless not upright. I just add the line "isakmp alive 30". Or was this not enough?
Do you have one tap, which options I could enable on my concentrator to fix it?
Thanks in advance.
Ludwig
Gold
verify whether the concentrator still maintain an active session for this particular pix. go monitoring | sessions.
further, to configure isakmp keepalive on the concentrator, go configuration | user management | groups | ipsec, the third options.
139
