Cisco VPN Concentrator, &Cisco Radius Server Problem..
Is there anyone that has implemented a Cisco VPN concentrator with a Cisco Radius Server that passes VPN login credentials to a Windows Domain Controller for authentication? If so, I need to know if anyone else is having authentication problems with VPN. Any help would be great.
Re: Cisco VPN Concentrator, &Cisco Radius Server Problem..
Robert,
The above mentioned set up should work fine. Could you post the logs from the VPN3000 when the user is having problems logging in.
Arul
likewise am having the same problem with the Radius server, able to authenicate the group but can't get by for a user..
131
