For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Concentrator (ver 4.7) VPN LAN overlap question
I have a question as to whether the following scenario is possible to configured.
I have a main site, that needs to create a VPN tunnel to remote client sites, assumably via a LAN-2-LAN connection. I need to be able to access all routable subnets on each remote client subnet.
The problem is that the remote sites themselves may have multiple subnets connected to their VPN concentrator as a function of their overall corporate star topology VPN environment. These subnet schemes may overlap from client to client. So while I've seen examples of how to overcome this problem if the immediate remote sites overalap, I haven't seen anything that talks about how to access the additional remote network subnets.
Is this possible?
SITEA <--> CLIENTA (10.0.1.x) <--> CLIENTA-SUBITE (10.0.2.x)
and at the same time
SITEA <--> CLIENTB(10.0.1.x) <--> CLIENTB-SUBSITE (10.0.2.x)
I guess I need to say that x number of subnets on my side, map up 1-to-1 on the x number of subnets on the remote side.
Any thoughts on if this is possible, and how best to address?
Thanks.
RS
  • Security Management
Re: Concentrator (ver 4.7) VPN LAN overlap question
Hey rstromberg , You would need to configure your concentrator to do NAT over Lan-to-Lan VPN. Take a look at this url to see if this would help you out.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00801ae24c.shtml
Thanks fo much for replying. That work fine, but I have an additional layer of complexity, I think.
I have multiple non-consecutive nets on the client end that I need to be able to NAT. I haven't seen how I can apply additional subnets, or even just a bunch of /32 NAT statements that will take my network, and map it up to multiple IPs from different networks on the remote end.
RS
109
