Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
config backup via snmp for asa 5520 does not work !
Ok, basically the whole snmp setup does not work with may asa.
What kind of MIBs are supported, and how do I backup my config using snmp ? For normal IOS I have a perl script running , but that does not work for ASA.
I thought maybe to use scp would be a good idea, but scp is not supported with the command "copy run scp ".
I would really appreciate some help on this issue.
1 REPLY
Re: config backup via snmp for asa 5520 does not work !
What are other workarounds for backing up the config file, if snmp does not work ???
It seems like I am not even able to set a rw community string.
I was trying to use scp, but it seems like this does not work either, and I tried some ssh-perl-script, and this also did not work, because of the poor ssh implementaion.
And now I have to do a copy run disk0: manually every night ? Come on, .... I don´t believe this.
Please provide some feedback, thanks.
343
