CSM 4.2 sp1 and strange deploy and monitoring behaviour
r.spiandorello
Hi, recently I have upgrade a CSM installation to 4.2 sp1 release on 2008 R2 VM server with 8 GB RAM.
I've noted the followings:
1- if I try to deploy policy on many device, the deploy manager stops on updating devices and never switch to downloading phase.
2- I see https connection to devices with login "" on CS-MARS caming from CSM, even if nothing is configured on CSM performance monitor. All devices credentials are correct.
Any suggest ?
thanks
r.spiandorello
Hi, I've found the event manager enabled even if the server has only 8 GB of RAM.
Hi, I have no error if I deploy 4 devices, but if I try to deploy 10 or more devices I received the following error for each device:
Status:
Failed: uploading divice ...
Message:
System error
Description:
Device provisioning failed
Java heap space
Action:
Please retry the operation. If the prblem persists, ....
I restart the server and 4 by 4 I'm able to deploy every device.
thanks
r.spiandorello
Hi, I have modified the CSM configuration, as suggested in deployment guide, for large site. Now the deployment for 100 devices stop after 20 devices.
thanks
