Highlighted
Community Member
CSM 4.2 SP1 Performance Monitor with Remote External ASA firewalls
I've been using CSM only for management so far, but I'm interested in using Performance Monitor to monitor Remote Access and Site to Site VPN performance, but seem to be doing somethign wrong :-(
The CSM server is behind an ASA at the main site is on address 192.168.1.100
The ASA at the main site  has address 192.168.1.1 as its internal address and 10.0.0.1 as its external address
The remote ASA has address 10.0.0.2 as its external address and 192.168.2.1 as its internal address
There is a site to site IPSec tunnel between the main site ASA and the remote site ASA with a cryptomap to include all traffic between the two internal networks
The ASA is configured with "management-access inside"
The ASA is configured with snmp as below
snmp-server host inside 192.168.1.100 community public version 1
snmp-server community public
I then tried to import the device into Performance Monitor using the internal IP address, but the import fails with the below error message
The Device 192.168.2.1 could not be imported because the SNMP request timed out.
1 device failed to be imported. To monitor this device, you must import it again.
Any suggestions as to what I'm doing wrong would be appreciated
Everyone's tags (6)
697
