Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DFM device discovery issue "Devices stuck in Questioned state"
We have LMS 3.0.1 installed with DFM 3.0.4 The devices are showing Questioned with Error code "SNMP timeout" with no specific reason. The snmpwalk is coming for the device as I checked with snmpwalk command. The only device discovered as"known" has ICMP permitted from Server to device and no other device has. They only have SNMP permit. Can this affect the dicovery?? or what else can I try....Please suggest!!
Rgds
1 ACCEPTED SOLUTION
Re: DFM device discovery issue "Devices stuck in Questioned stat
Yes. DFM requires that all devices be both SNMP and ICMP reachable. DFM uses ICMP to verify reachability to all IP addresses on the device. However, at the very least, the address by which you manage the device MUST be ICMP reachable.
Thanks Joe. I have communicated the same further.
212
