05-01-2009 03:49 AM - edited 02-21-2020 03:26 AM
I have a phase 2 DMVPN network with approx 40 spoke routers and dual hub routers. 90% of this is working very well. However I have 3 or 4 spoke routers that are unable to communicate with each other directly (traffic goes via the hub router between these specific sites) however they are able to coomunicate directly with the other 35 or so routers. I think this is an NHRP issue as when I do show ip nhrp detail on one of these 4 routers, the other 3 routers display a (no socket) entry. I am able to clear this "sometimes" by clear ip nhrp. Whenever the (no scoket) entry is there spoke to spoke communication does not work. Any help would be greatly appreciated.
Solved! Go to Solution.
05-07-2009 06:01 AM
Have you checked this bug CSCsw18019
TEA spoke-spoke communication going thru hub if nhrp cache non-author.
05-07-2009 06:01 AM
05-08-2009 02:19 AM
pradeepde,
Thank you very much for your response. I think you may be right, I have upgraded the IOS to a maintenance release 12.4.15T9 and this does appear to have fixed the problem.
Thanks again
