Community Member
Easy VPN Remote + Site to Site on the same Interface
This is the case:
We have a remote site which needs to be connected to our office, and at the same time be connected to a third party, both using VPN.
The connection to our office is done by EasyVPN and the one to the third party is done by using a crypto-map (ISKMP tunnel). According to the documentation, this should be possible:
Easy VPN Remote and Site to Site on the same Interface
This feature allows the Easy VPN remote and site to site (crypto map) to be supported on the same interface, making it possible to both establish a tunnel to another Easy VPN server and have another site to site on the same interface simultaneously. A typical application would be a third-party VPN service provider that is managing a remote router via the site-to-site tunnel and using Easy VPN Remote to connect the remote site to a corporate Easy VPN server.
For more information about the Easy VPN Remote and Site to Site on the Same Interface feature, see "Easy VPN Remote and Site to Site on the Same Interface" in the section " Additional References
:End Quote:
Have anyone done this, or have ideas of how it should be done ? I'm very interested in the document that's being referred to, it's exactly our case...
Txs, in advance.
Henrik Thilander
