how to configure BWth restriction on 7200
davemac2626
Hi all
I would like some help in configuring interfaces on a 7200.
Ideally is there anyway you can configure any interface to auto shutdown if a bandwidth limit has been reached?
As far as I am aware I can configure the following command to drop packets:
rate-limit output 10000000 2000 2000 conform-action continue exceed-action drop
however I would like the interface if possible to be shutdown.....
I have seen a TCL script available (TCP_Syn_Flow_Detection.tar) that will carry out this action if the Syn flow of TCP packets has hit a certain limit however not sure if this will suffice....
Any help anyone can give me would be most appreciated.
Router config is:
#sh run
Building configuration...
Current configuration : 30077 bytes
! Last configuration change at 19:22:26 UTC Tue Nov 29 2011 by support
! NVRAM config last updated at 19:22:28 UTC Tue Nov 29 2011 by support
upgrade fpd auto
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname THN-7201-A
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock summer-time GB recurring last Sun Mar 2:00 last Sun Oct 2:00
ip source-route
ip cef
no ipv6 cef
memory-size iomem 0
username support secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
archive
log config
  hidekeys
path tftp://xx.xxx.xxx.xx/SIPCOM/THN-7201-A
write-memory
time-period 1440
ip ftp username sipcom_backup
ip ftp password 7 xxxxxxxxxxxxxxxxxxxxxxxx
interface Loopback0
ip address xx.xxx.xxx.x 255.255.255.255
interface Tunnel0
bandwidth 100000
ip address xx.xxx.xxx.x 255.255.255.252
keepalive 10 3
tunnel source FastEthernet0/0
tunnel destination xxx.xxx.x.xx
interface Tunnel64
bandwidth 2000
ip address xxx.xx.xx.x 255.255.255.252
keepalive 10 3
tunnel source GigabitEthernet0/1
tunnel destination xxx.xxx.xxx.xxx
interface FastEthernet0/0
description TATA CCT 347764
ip address xxx.xxx.x.xx 255.255.255.252
ip access-group SIPCOM_VOICERECORD_IN in
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface GigabitEthernet0/0
description THN PRIVATE
ip address xx.xxx.xxx.xxx 255.255.255.128
duplex auto
speed 1000
media-type rj45
negotiation auto
standby 0 ip xx.xxx.xxx.xxx
standby 0 preempt
interface GigabitEthernet0/1
description VTL LINK 1
ip address xxx.xxx.xx.xx 255.255.255.252
ip access-group 101 in
ip flow ingress
ip nat outside
duplex full
speed 1000
media-type rj45
negotiation auto
interface GigabitEthernet0/2
description BT IPEX LINK 1
ip address xx.xxx.xxx.xxx 255.255.255.248
duplex full
speed 1000
negotiation auto
interface GigabitEthernet0/3
description THN PUBLIC
ip address xx.xxx.xxx.x 255.255.255.128
ip access-group 117 in
ip nat inside
duplex auto
speed auto
negotiation auto
standby 1 ip xx.xxx.xxx.x
standby 1 preempt
interface Group-Async0
physical-layer async
no ip address
encapsulation slip
router eigrp 200
redistribute connected metric 1500 0 1 255 1500 route-map EIGRP-TUNNEL
network xx.xxx.xxx.xxx 0.0.0.0
network xx.xxx.xxx.x 0.0.0.0
no auto-summary
router ospf 100
log-adjacency-changes
redistribute connected subnets
network xx.xx.x.x 0.0.0.255 area 0
router bgp 47631
bgp log-neighbor-changes
neighbor xx.xxx.xxx.xxx remote-as 47631
neighbor xxx.xxx.x.xx remote-as 6453
neighbor xxx.xxx.xx.xx remote-as 8190
address-family ipv4
  redistribute connected route-map SIPCOM
  redistribute static
  neighbor xx.xxx.xxx.xxx activate
  neighbor xx.xxx.xxx.xxx next-hop-self
  neighbor xxx.xxx.x.xx activate
  neighbor xxx.xxx.x.xx weight 100
  neighbor xxx.xxx.xx.xx activate
  neighbor xxx.xxx.xx.xx weight 200
  no auto-summary
  no synchronization
  network xx.xxx.xxx.0 mask 255.255.248.0
  network xx.xxx.xxx.0 mask 255.255.255.0
exit-address-family
ip forward-protocol nd
ip route x.x.x.x 0.0.0.0 xxx.xxx.xx.xx 10
ip route xx.x.x.x 255.255.0.0 xx.xxx.224.254
ip route xx.x.xx.176 255.255.255.255 195.219.0.13
ip route xx.xxx.224.0 255.255.248.0 FastEthernet0/0
ip route xx.xxx.224.160 255.255.255.224 xx.xxx224.8
ip route xx.xxx.225.0 255.255.255.0 xx.xxx.224.54
ip route xx.xxx.226.16 255.255.255.240 xx.xxx.224.151
ip route xx.xxx.226.128 255.255.255.240 xx.xxx.224.8
ip route xx.xxx.226.228 255.255.255.252 xx.xxx.224.80
ip route xx.xxx.226.248 255.255.255.252 xx.xxx.224.126
ip route xx.xxx.226.252 255.255.255.252 xx.xxx.224.126
ip route xx.xxx.227.0 255.255.255.0 xx.xxx.224.126
ip route xx.xxx.228.0 255.255.255.0 xx.xxx.224.126
ip route xx.xxx.229.0 255.255.255.0 xx.xxx.224.126
ip route xx.xxx.229.0 255.255.255.224 xx.xxx.224.126
ip route xx.xxx.229.240 255.255.255.248 172.16.64.2
ip route xx.xxx.230.0 255.255.255.0 xx.xxx.224.126
ip route xx.xxx.230.254 255.255.255.255 xx.xxx.224.126
ip route xx.xxx.231.0 255.255.255.0 xx.xxx.224.126
ip route xx.xxx.191.208 255.255.255.248 xx.xxx.224.126
ip route xxx.xx6.163.112 255.255.255.255 xx.xxx.224.126
ip route xxx.xx6.163.113 255.255.255.255 xx.xxx.224.126
ip route xxx.xx.8.0 255.255.255.0 xx.xxx.224.254
ip route xxx.xx.9.0 255.255.255.0 xx.xxx.224.126
ip route xxx.xx.20.0 255.255.255.0 xx.xxx.224.126
ip route xxx.xx.0.0 255.255.0.0 xx.xxx.224.126
ip route xxx.xx8.0.5 255.255.255.255 xx.xxx.224.254
ip route xxx.xx8.64.0 255.255.255.0 xxx.xx.xx.2
ip route xxx.xx8.70.0 255.255.255.0 xx.xxx.224.126
ip route xxx.xx.0.0 255.255.0.0 Null0
no ip http server
no ip http secure-server
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/3
ip flow-export version 9
ip flow-export destination xxx.xx.x.75 9996
no ip nat service skinny tcp port 2000
no ip nat service sip udp port 5060
ip nat inside source list 106 interface GigabitEthernet0/3 overload
ip nat inside source static tcp 172.16.9.20 22 xx.xxx.224.30 22 extendable
ip nat inside source static tcp xxx.xx.x.20 443 xx.xxx.224.30 443 extendable
ip nat inside source static tcp xxx.xx.x.22 22 xx.xxx.224.31 22 extendable
ip nat inside source static tcp xxx.xx.x.22 443 xx.xxx.224.31 443 extendable
ip nat inside source static tcp xxx.xx.x.24 22 xx.xxx.224.32 22 extendable
ip nat inside source static tcp xxx.xx.x.24 443 xx.xxx.224.32 443 extendable
ip access-list standard EIGRP
permit xx.xxx.224.128 0.0.0.127
ip access-list standard SIPCOM
permit xx.xxx.224.0 0.0.7.255
permit xx.xxx.224.0 0.0.0.255
ip access-list standard SIPCOM/21
deny   xx.xxx.224.0 0.0.0.255
deny   xx.xxx.225.0 0.0.0.255
deny   xx.xxx.226.0 0.0.0.255
deny   xx.xxx.227.0 0.0.0.255
deny   xx.xxx.228.0 0.0.0.255
deny   xx.xxx.229.0 0.0.0.255
deny   xx.xxx.230.0 0.0.0.255
deny   xx.xxx.231.0 0.0.0.255
permit xx.xxx.224.0 0.0.0.7
ip access-list extended SIPCOM_VOICERECORD_IN
permit ip host xx.xx.xx.24 host xx.xxx.224.30
permit ip xxx.xxx.x.0 0.0.0.255 host xx.xxx.224.30
deny   ip any host xx.xxx.224.30
permit ip host xx.xx.xx.24 host xx.xxx.224.31
permit ip xxx.xxx.x.0 0.0.0.255 host xx.xxx.224.31
deny   ip any host xx.xxx.224.31
permit ip host xx.xx.xx.24 host xx.xxx.224.32
deny   ip any host xx.xxx.224.32
permit ip host xxx.xxx.xx.101 xx.xxx.226.0 0.0.0.255
permit ip host xxx.xxx.xx.101 any
deny   ip host xxx.xxx.xx.250 any
permit ip host xxx.xxx.xxx.44 any
permit ip host x.xx.xxx.218 any
deny   ip host xxx.xxx.xxx.118 any
permit ip host xxx.xxx.xx.54 any
permit udp any host xx.xxx.224.12 range 50000 59998
permit udp any host xx.xxx.224.17 range 50000 59998
permit tcp host xx.xxx.xx.215 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.xxx.18 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.xxx.139 host xx.xxx.224.5 eq www
permit tcp host xxx.x.xxx.60 host xx.xxx.224.5 eq www
deny   ip host xx.xxx.xxx.222 host xx.xxx.224.5
permit tcp host xxx.xx.xx.146 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.xx.194 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.xxx.116 host xx.xxx.224.5 eq www
permit ip host x.x.x.x host xx.xxx.224.5
permit udp any host xx.xxx.224.15 eq tftp
permit udp any host xx.xxx.224.16 eq tftp
permit tcp any host xx.xxx.224.12 eq 2000
permit tcp any host xx.xxx.224.15 eq 2000
permit tcp any host xx.xxx.224.13 eq 2000
permit tcp any host xx.xxx.224.18 eq 2000
permit udp any host xx.xxx.224.13 eq tftp
permit udp any host xx.xxx.224.18 eq tftp
permit tcp host xx.xxx.x.x host xx.xxx.224.5 eq 3389
permit tcp host xx.xxx.x.xxx host xx.xxx.224.5 eq www
permit tcp host xx.xxx.xxx.xxx host xx.xxx.224.5 eq www
permit tcp host xx.xxx.xxx.162 host xx.xxx.224.5 eq www
permit tcp host xxx.xxx.x.108 host xx.xxx.224.5 eq www
permit tcp host xxx.xxx.x.13 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.x.82 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.x.76 host xx.xxx.224.5 eq www
permit tcp host xxx.x.xx.185 host xx.xxx.224.5 eq www
permit tcp host xxx.xxx.x.166 host xx.xxx.224.5 eq www
permit tcp host xx.x.x.33 host xx.xxx.224.5 eq www
permit tcp host xx.xxx.x.242 host xx.xxx.224.5 eq www
permit tcp x.x.x.0 0.0.1.255 any eq 443
permit tcp x.x.x.0 0.0.1.255 any eq www
permit tcp x.x.x.0 0.0.1.255 any eq 2208
permit tcp x.x.x.0 0.0.1.255 any eq 2206
permit tcp x.x.x.0 0.0.1.255 any eq 2220
permit ip host x.x.x.7 any
permit ip host x.x.x.189 any
permit ip host x.x.x.41 any
deny   ip any host xx.xxx.x.7
permit ip any xx.xxx.x.160 0.0.0.31
permit tcp host xx.x.x.36 host xx.xxx.224.5 eq www
permit tcp host x.x.x.227 host xx.xxx.224.5 eq www
permit tcp host x.x.x.65 host xx.xxx.224.5 eq www
permit tcp host x.x.x.166 host xx.xxx.224.5 eq www
permit tcp host x.x.x.124 host xx.xxx.224.5 eq www
permit tcp host x.x.x.193 host xx.xxx.224.5 eq www
permit tcp host x.x.x.138 host xx.xxx.224.5 eq www
permit tcp host x.x.x.98 host xx.xxx.224.5 eq www
permit tcp host x.x.x.171 host xx.xxx.224.5 eq www
permit tcp host x.x.x.114 host xx.xxx.224.5 eq www
permit tcp host x.x.x.153 host xx.xxx.224.5 eq www
permit tcp host x.x.x.116 host xx.xxx.224.5 eq www
permit tcp host x.x.x.32 host xx.xxx.224.5 eq www
permit tcp host x.x.x.x host xx.xxx.224.5 eq www
permit tcp host x.x.x.59 host xx.xxx.224.5 eq www
permit tcp host x.x.x.18 host xx.xxx.224.5 eq www
permit tcp host x.x.x.195 host xx.xxx.224.5 eq www
permit tcp host x.x.x.28 host xx.xxx.224.5 eq www
permit tcp host x.x.x.44 host xx.xxx.224.5 eq www
permit ip host x.x.x.114 host xx.xxx.224.5
permit tcp host x.x.x.114 host xx.xxx.224.5 eq ftp
permit tcp host x.x.x.114 host xx.xxx.224.5 eq ftp-data
permit udp host xx.xxx.224.40 host xx.xxx.224.5 eq 20
permit tcp host xx.xxx.224.40 host xx.xxx.224.5 eq www
permit udp host xx.xxx.224.40 host xx.xxx.224.5 eq 21
permit tcp host x.x.x.179 host xx.xxx.224.5 eq www
permit tcp host x.x.x.243 host xx.xxx.224.5 eq www
permit tcp x.x.x.0 0.0.15.255 host xx.xxx.224.5 eq smtp
permit tcp x.x.x.0 0.0.7.255 host xx.xxx.224.5 eq smtp
permit tcp x.x.x.0 0.0.1.255 host xx.xxx.224.5 eq smtp
deny   ip any host xx.xxx.224.13
deny   ip any host xx.xxx.224.14
deny   ip any host xx.xxx.224.17
deny   ip any host xx.xxx.224.18
permit tcp host x.x.x.151 host xx.xxx.224.10 eq 22
permit tcp host x.x.x.151 host xx.xxx.224.11 eq 22
permit tcp host x.x.x.151 host xx.xxx.224.15 eq 22
permit tcp host x.x.x.151 host xx.xxx.224.16 eq 22
deny   ip any host xx.xxx.224.12
permit tcp any host xx.xxx.224.10 eq www
permit tcp 195.245.230.0 0.0.1.255 host xx.xxx.224.5 eq smtp
permit tcp any host xx.xxx.224.10 eq 2208
permit tcp any host xx.xxx.224.10 eq 443
permit tcp any host xx.xxx.224.11 eq www
permit tcp any host xx.xxx.224.11 eq 2208
permit tcp any host xx.xxx.224.11 eq 443
permit tcp any host xx.xxx.224.15 eq www
permit tcp any host xx.xxx.224.15 eq 443
permit tcp any host xx.xxx.224.16 eq www
permit tcp any host xx.xxx.224.16 eq 443
deny   ip any host xx.xxx.224.5
deny   ip any host xx.xxx.224.10
deny   ip any host xx.xxx.224.11
deny   ip any host xx.xxx.224.15
deny   ip any host xx.xxx.224.16
deny   ip any xx.xxx.x.128 0.0.0.127
deny   ip any xx.xxx.x.0 0.0.0.255
permit ip any xx.xxx.x.228 0.0.0.3
permit ip any any
permit tcp host x.x.x.111 host xx.xxx.224.5 eq www
ip sla responder
ip sla 10
udp-jitter x.x.x.61 17000
frequency 30
ip sla schedule 10 life 300 start-time after 00:05:00 recurring
ip sla 100
udp-jitter xx.xxx.x.6 50002 source-ip xx.xxx.226.5 source-port 50004
tos 184
tag Tunnel0_Test
frequency 20
ip sla schedule 100 life forever start-time now
ip sla 101
udp-jitter xx.xxx.224.126 50002 source-ip xx.xxx.224.2 source-port 50004
tag Tunnel0_Test
frequency 20
ip sla schedule 101 life forever start-time now
logging alarm informational
access-list 30 permit x.x.0.0 0.0.255.255
access-list 30 permit x.x.x.0 0.0.0.255
access-list 34 permit x.x.x.28
access-list 34 permit xx.xxx.224.42
access-list 34 permit xx.xxx.224.40
access-list 34 permit xxx.xx.x.79
access-list 34 permit xxx.xx.x.75
access-list 34 permit x.x.x.0 0.0.255.255
access-list 101 permit ip host x.x.x.101 any
access-list 101 deny   ip host x.x.x.250 any
access-list 101 permit ip host x.x.x.218 any
access-list 101 permit udp any host xx.xxx.224.12 range 50000 59998
access-list 101 permit udp any host xx.xxx.224.17 range 50000 59998
access-list 101 permit ip host x.x.x.44 any
access-list 101 permit ip any xx.xxx.x.160 0.0.0.31
access-list 101 permit tcp host x.x.x.x host xx.xxx.224.5 eq www
access-list 101 deny   ip host x.x.x.x host xx.xxx.224.5
access-list 101 permit ip host x.x.x.x host xx.xxx.224.80
access-list 101 deny   tcp any host xx.xxx.224.80 eq 22
access-list 101 deny   tcp any host xx.xxx.224.80 eq www
access-list 101 deny   tcp any host xx.xxx.224.81 eq www
access-list 101 deny   tcp any host xx.xxx.224.81 eq 22
access-list 101 deny   tcp any host xx.xxx.224.81 eq telnet
access-list 101 permit udp any host xx.xxx.224.15 eq tftp
access-list 101 permit udp any host xx.xxx.224.16 eq tftp
access-list 101 permit tcp any host xx.xxx.224.12 eq 2000
access-list 101 permit tcp any host xx.xxx.224.15 eq 2000
access-list 101 permit tcp any host xx.xxx.224.13 eq 2000
access-list 101 permit tcp any host xx.xxx.224.18 eq 2000
access-list 101 permit udp any host xx.xxx.224.13 eq tftp
access-list 101 permit udp any host xx.xxx.224.18 eq tftp
access-list 101 deny   tcp any host xx.xxx.224.80 eq telnet
access-list 101 permit ip any host xx.xxx.224.8
access-list 101 permit tcp host x.x.x.162 host xx.xxx.224.5 eq www
access-list 101 permit ip any host xx.xxx.224.9
access-list 101 permit udp any any eq ntp
access-list 101 permit icmp host x.x.x.28 any
access-list 101 permit icmp host x.x.x.18 any
access-list 101 permit ip any host xx.xxx.224.40
access-list 101 permit ip host x.x.x.18 any
access-list 101 permit tcp host x.x.x.18 host xx.xxx.224.10 eq www
access-list 101 permit tcp host x.x.x.18 host xx.xxx.224.10 eq 443
access-list 101 permit tcp host x.x.x.18 host xx.xxx.224.10 eq 2208
access-list 101 permit ip host x.x.x.24 any
access-list 101 permit ip x.x.x.0 0.0.0.255 any
access-list 101 permit ip x.x.x.0 0.0.0.255 host xx.xxx.224.36
access-list 101 permit tcp any host xx.xxx.224.10 eq www
access-list 101 permit tcp any host xx.xxx.224.10 eq 843
access-list 101 permit tcp any host xx.xxx.224.10 eq 2208
access-list 101 permit tcp any host xx.xxx.224.10 eq 443
access-list 101 permit tcp any host xx.xxx.224.11 eq www
access-list 101 permit tcp any host xx.xxx.224.11 eq 2208
access-list 101 permit tcp any host xx.xxx.224.11 eq 443
access-list 101 permit tcp any host xx.xxx.224.15 eq www
access-list 101 permit tcp any host xx.xxx.224.15 eq 443
access-list 101 permit tcp any host xx.xxx.224.16 eq www
access-list 101 permit tcp any host xx.xxx.224.16 eq 443
access-list 101 permit tcp host x.x.x.28 any eq 22
access-list 101 permit tcp host x.x.x.3 any eq 22
access-list 101 permit tcp host x.x.x.3 any eq www
access-list 101 permit tcp host x.x.x.3 any eq 443
access-list 101 permit tcp host x.x.x.2 any eq www
access-list 101 permit ip host x.x.x.114 host xx.xxx.224.5
access-list 101 permit tcp host x.x.x.114 host xx.xxx.224.5 eq ftp
access-list 101 permit tcp host x.x.x.114 host xx.xxx.224.5 eq ftp-data
access-list 101 permit tcp host x.x.x.2 any eq 443
access-list 101 permit tcp x.x.x.0 0.0.1.255 any eq 443
access-list 101 permit tcp x.x.x.0 0.0.1.255 any eq www
access-list 101 permit tcp x.x.x.0 0.0.1.255 any eq 2208
access-list 101 permit tcp x.x.x.0 0.0.1.255 any eq 2206
access-list 101 permit tcp x.x.x.0 0.0.1.255 any eq 2220
access-list 101 permit tcp host x.x.x.2 any eq 22
access-list 101 permit tcp host x.x.x.179 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.13 any eq 1099
access-list 101 permit tcp host x.x.x.104 any eq 1099
access-list 101 permit tcp host x.x.x.13 any eq 2208
access-list 101 permit tcp host x.x.x.104 any eq 2208
access-list 101 permit tcp host x.x.x.13 any eq 36001
access-list 101 permit tcp host x.x.x.13 any eq 36002
access-list 101 permit tcp host x.x.x.104 any eq 36001
access-list 101 permit tcp host x.x.x.104 any eq 36002
access-list 101 permit tcp host x.x.x.104 any eq 443
access-list 101 permit tcp host x.x.x.104 any eq www
access-list 101 permit tcp host x.x.x.13 any eq www
access-list 101 permit tcp host x.x.x.114 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.13 any eq 443
access-list 101 permit tcp host x.x.x.189 any eq 22
access-list 101 permit tcp host x.x.x.7 any eq 22
access-list 101 permit tcp host x.x.x.41 any eq 22
access-list 101 permit tcp host x.x.x.189 any eq www
access-list 101 permit tcp host x.x.x.7 any eq www
access-list 101 permit tcp host x.x.x.41 any eq www
access-list 101 permit tcp host x.x.x.189 any eq 443
access-list 101 permit tcp host x.x.x.7 any eq 443
access-list 101 permit tcp host x.x.x.41 any eq 443
access-list 101 permit tcp host x.x.x.189 any eq 1099
access-list 101 permit tcp host x.x.x.2 any eq 1099
access-list 101 permit tcp host x.x.x.7 any eq 1099
access-list 101 permit tcp host x.x.x.41 any eq 1099
access-list 101 permit tcp host x.x.x.189 any eq 2208
access-list 101 permit tcp host x.x.x.2 any eq 2208
access-list 101 permit tcp host x.x.x.7 any eq 2208
access-list 101 permit tcp host x.x.x.41 any eq 2208
access-list 101 permit tcp host x.x.x.189 any eq 36001
access-list 101 permit tcp host x.x.x.2 any eq 36001
access-list 101 permit tcp host x.x.x.7 any eq 36001
access-list 101 permit tcp host x.x.x.41 any eq 36001
access-list 101 permit tcp host x.x.x.189 any eq 36002
access-list 101 permit tcp host x.x.x.2 any eq 36002
access-list 101 permit tcp host x.x.x.7 any eq 36002
access-list 101 permit tcp host x.x.x.41 any eq 36002
access-list 101 permit tcp host x.x.x.151 host xx.xxx.224.15 eq 22
access-list 101 permit tcp host x.x.x.151 host xx.xxx.224.16
access-list 101 permit tcp host x.x.x.151 host xx.xxx.224.11
access-list 101 permit tcp host x.x.x.151 host xx.xxx.224.10 eq 22
access-list 101 permit ip host x.x.x.x host xx.xxx.224.36
access-list 101 permit ip x.x.0.0 0.0.255.255 any
access-list 101 permit ip host x.x.x.206 host xx.xxx.224.2
access-list 101 permit ip xx.xxx.224.0 0.0.31.255 xx.xxx.228.0 0.0.0.255
access-list 101 permit ip host x.x.x.28 any
access-list 101 permit ip any xx.xxx.226.228 0.0.0.3
access-list 101 permit ip any xx.xxx.226.128 0.0.0.15
access-list 101 deny   ip any xx.xxx.226.0 0.0.0.255
access-list 101 permit tcp host x.x.x.194 host xx.xxx.224.5 eq 3389
access-list 101 permit tcp any host xx.xxx.224.5 eq 443
access-list 101 permit ip host x.x.x.x host xx.xxx.224.5
access-list 101 permit udp host x.x.x.x host xx.xxx.224.5 eq domain
access-list 101 permit tcp host x.x.x.242 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.36 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.65 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.124 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.195 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.138 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.98 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.171 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.153 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.116 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.193 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.32 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.18 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.243 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.28 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.44 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.108 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.82 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.76 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.59 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.134 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.33 host xx.xxx.224.5 eq www
access-list 101 permit ip x.x.x.0 0.0.7.255 host xx.xxx.224.5
access-list 101 permit tcp host x.x.x.210 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.185 host xx.xxx.224.5 eq www
access-list 101 permit tcp host x.x.x.227 host xx.xxx.224.5 eq www
access-list 101 permit tcp x.x.x.0 0.0.15.255 host xx.xxx.224.5 eq smtp
access-list 101 permit tcp x.x.x.0 0.0.7.255 host xx.xxx.224.5 eq smtp
access-list 101 permit tcp x.x.x.0 0.0.1.255 host xx.xxx.224.5 eq smtp
access-list 101 deny   ip any host xx.xxx.224.7
access-list 101 deny   ip any host xx.xxx.224.5
access-list 101 deny   ip any host xx.xxx.224.20
access-list 101 deny   ip any host xx.xxx.224.27
access-list 101 deny   ip any xx.xxx.224.128 0.0.0.127
access-list 101 deny   ip any xx.xxx.228.0 0.0.0.255
access-list 101 permit ip host x.x.x.24 host xx.xxx.224.32
access-list 101 permit ip host x.x.x.24 host xx.xxx.224.31
access-list 101 permit ip host x.x.x.24 host xx.xxx.224.30
access-list 101 permit ip x.x.x.0 0.0.0.255 host xx.xxx.224.30
access-list 101 permit ip x.x.x.0 0.0.0.255 host xx.xxx.224.31
access-list 101 permit ip x.x.x.0 0.0.0.255 host xx.xxx.224.32
access-list 101 permit ip x.x.x.0 0.0.0.255 host xx.xxx.224.33
access-list 101 deny   ip any host xx.x.x.x
access-list 101 permit ip any any
access-list 102 permit ip xx.xx.xx.0 0.0.0.255 any
access-list 106 permit ip host xxx.xx.x.xx any
access-list 125 permit tcp xx.xxx.xxx.0 0.0.0.127 any eq smtp
access-list 125 permit ip host xx.xxx.xxx.x any
access-list 126 permit ip host xx.xxx.xxx.xxx host x.x.x.x
access-list 144 deny   tcp host xx.xxx.xxx.x any eq 445
access-list 144 deny   tcp host xx.xxx.xxx.x any eq 136
access-list 144 deny   tcp host xx.xxx.xxx.x any eq 137
access-list 144 deny   ip host xx.xxx.xxx.x xx.0.0.0 0.255.255.255
access-list 144 deny   tcp host xx.xxx.xxx.x any eq 135
access-list 144 permit tcp host xx.xxx.xxx.x any established
access-list 144 permit ip any any
snmp-server community c4rt3r RW 30
snmp-server community voiss RO 34
snmp-server community SIPcomMonitor RO 34
snmp-server location Telehouse North Rack18
snmp-server contact Support - 02033285000
snmp-server chassis-id THN-7201-A
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps flash insertion removal
snmp-server enable traps srp
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ima
snmp-server enable traps channel
snmp-server enable traps ip local pool
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bstun
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dial
snmp-server enable traps dlsw
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmobile
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps stun
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps pw vc
snmp-server enable traps event-manager
snmp-server enable traps director server-up server-down
snmp-server enable traps firewall serverstatus
snmp-server enable traps rf
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps alarms informational
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps mpls vpn
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host xxx.xx.x.xx version 2c SIPcomMonitor
route-map TATA permit 10
match ip address SIPCOM/21
set as-path prepend 47631 47631 47631
route-map IPEX permit 10
match ip address 126
route-map TITA permit 10
route-map VR-Outbound_SMTP permit 10
match ip address 125
route-map EIGRP-TUNNEL permit 10
match ip address EIGRP
control-plane
mgcp fax t38 ecm
dial-peer cor custom
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
ntp logging
ntp master
ntp server xxx.xx.xxx.xx
ntp server xx.xxx.xxx.xxx prefer
end
Martin Hruby
Hello
You might accomplish this using an EEM applet, like this:
event manager applet SHUT_IF_BW_ABOVE_100
 event tag 1.0 timer watchdog time 5
 action 1.0 info type interface-names regexp "Fa|Gi|Tu"
 action 1.1 foreach _iface "$_info_interface_names"
 action 1.1.1  cli command "show interfaces $_iface | i output rate"
 action 1.1.2  set bw "0"
 action 1.1.3  set result "none"
 action 1.1.4  regexp "5 minute output rate ([0-9]+)" "$_cli_result" result bw
 action 1.1.5.01  if $bw gt "100000000"
 action 1.1.5.02   puts "Interface $_iface is above 100Mbps ($bw)"
 action 1.1.5.03   cli command "enable"
 action 1.1.5.04   cli command "config t"
 action 1.1.5.05   cli command "interface $_iface"
 action 1.1.5.06   cli command "shutdown"
 action 1.1.5.07   cli command "end"
 action 1.1.5.08  else
 action 1.1.5.09   puts "Interface $_iface is below 100Mbps ($bw)"
 action 1.1.5.10 end
 action 1.2 end
 action 1.3   exit
The above script will retrieve a list of all interfaces (matching Fa or Gi or Tu in the interface name) every 5 seconds and get the current output rate from the show interfaces command. If this value is above 100Mbps then the interface is shutdown. Every 5 seconds an output is for all interfaces is given which shows the bandwidth utilization. The interfaces are not "un-shut" once the bandwidth returns to normal. You can modify this according to your needs, I'm sure you get the idea.
Best regards,
Martin
