Community Member
How to monitor connections dropped and rejected on the PIX/ASA firewall?
I need to monitor OID SNMP of the connections dropped and rejected on the PIX and ASA firewall. Is it possible?
If it is, which OID SNMP should I to monitor?
1 ACCEPTED SOLUTION
Re: How to monitor connections dropped and rejected on the PIX/A
Syslogs and Netflow (introduced in 8.2 version) are your options.
No MIB can give you the conn numbers.
PK
Do you just want the count (number)?
Syslog would be the way of choice to get insight into these connections and not SNMP. I don't think any SNMP MIB is supported offering this functionality.
Farrukh
Community Member
Yes, I need only the count (number) of connections dropped and rejected.
PK
Community Member
Ok PK, thank you very much.
Fabiano
518
