11-20-2006 07:43 AM - edited 02-21-2020 01:19 AM
I have a Site 2 Site VPN set up from my office to my home. One of my applications uses multicast to communicate with a server on the other end of the VPN. Is there anyway I can enable IGMP over my VPN connection??
Solved! Go to Solution.
11-21-2006 01:06 AM
The IPSec, in IPSec Direct Encapsulation doesnt support multicast
In order to get Multicast enabled across the VPN you need use GRE
Please visit for more info:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a008074f26a.pdf
M.
Hope that helps rate if it does
11-21-2006 01:06 AM
M.
02-01-2014 08:26 PM
hi all ,
can any one help me with setup vpn with igmp from ccp ??
i need to setup it from gui
if it is hard frm gui dont mind from cli
regards
