IPSec over GRE with Cat6503 and SPA IPSec
Hi all,
I trying to test a solution using IPSEC-SPA to encrypt traffic and put it over a tunnel interface ( mode ipip or GRE ).
The tunnel encapsulation should be done by Cat65XX itself.From documentation and from my first test results that is not permitted to configured the crypto map under the tunnel interface as wanted.
Thera are no solution for this?
thanks
Stefano
1 REPLY
Re: IPSec over GRE with Cat6503 and SPA IPSec
Sure it's possible.......
You don't need to apply the Crypto Map to the Tunnel interface.
Apply the Crypto Map to the "Inside" port (VLAN as usual) from VPN-SPA's perspective.
Connect the "Outside" port from VPN-SPA's perspective to the "Inside" port (VLAN).
Use the "Inside" port (VLAN) as the Tunnel Source.
interface vlan 1000
description - VPNSPA Inside VLAN
ip address 1.1.1.1 255.255.255.0
crypto map MAP_STATIC
crypto engine slot 1/0
interface vlan 1001
description - VPNSPA Outside VLAN
crypto connect vlan 1000
interface tunnel 1000
bandwidth 1000
ip address 9.9.9.1 255.255.255.0
tunnel source vlan 1000
tunnel destination 2.2.2.2
access-list 100 permit gre host 1.1.1.1 host 2.2.2.2
***This is of course assuming that the peer's Tunnel ip is 9.9.9.x/24 and it's global IP is 2.2.2.2***
Also http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_14459.htm#wp1273613 (this is for VPNSM but config is relatively the same. Note 'Switch #1, Tunnel intf #1' should read "tunnel source vlan 2")
Good Luck,
Don
119
