LLQ with EZVPN over DSL (PPPoA) with Dialer Interface
I need to configure QoS for VoIP on a DSL router using PPPoA. The VoIP traffic is going over the EZVPN tunnel.
My problem is that a 'show policy-map interface dialer0' shows packets/bytes but I never get any hits in packets matched/bytes matched fields.
I've even removed EZVPN and applied test policies to internet traffic but still get no hits. So my access-list and the classes are being matched correctly it just that queuing does not seem to be working. I searched CCO and I can't find any examples of LLQ with PPPoA so it may not be supported. Any ideas anyone?
Chris
Service-policy output: Pol-OutClassify
Class-map: Node4-EZVPN (match-all)
483 packets, 31878 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef (46)
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 128 (kbps) Burst 3200 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: test (match-any)
2835 packets, 187110 bytes
Match: access-group 115
30 second rate 0 bps
Queueing
Output Queue: Conversation 137
Bandwidth 10 (%)
Class-map: class-default (match-any)
342 packets, 280978 bytes
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 128
(total queued/total drops/no-buffer drops) 0/0/0
QoS Set
dscp default
Packets marked 349
Re: LLQ with EZVPN over DSL (PPPoA) with Dialer Interface
are you sure, that the VoIP traffic is marked properly as ef? Also with EzVPN have you configured qos pre-classify on the tunnel?
Can you enable nbar protocol discovery at the input interface to check the protocols and existance of VoIP traffic.
Also use "auto qos voip" as a start. The latter should reconfigure your router preperly for VoIP.
Hope this helps! Please rate all posts.
Regards, Martin
qos pre-classify isn't available with EZVPN. It isn't required as the DSCP marking are automatically copied from the original IP packet header to the IPSec packet header.
I've actually resolved this now.
If you read the SRND for QoS it discusses QoS over broadband (www.cisco.com/go/srnd). The problem was that the service policy must be applied to the ATM sub-interface and not the dialler interface. Also you need to specify that the sub-interface is not UBR by specifying VRT-NRT, VBR-RT or CBR parameters as below.
interface ATM0/0/0
bandwidth 256
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
vbr-nrt 288 288
encapsulation aal5mux ppp dialer
dialer pool-member 1
service-policy output WAN-QOS
With this configuration a 'show policy-map int atm0/0/0' now shows packets matched and bytes matched.
Chris
318
