09-22-2005 06:56 AM - edited 02-21-2020 12:24 AM
Hi together,
I have a vrf configuration on a cpe.
Now I wanna send all logging messages from loopback 10, and also from the vrf.
for commands like tftp, snmp, ntp the packets where send from the vrf with src ip of loopback 10.
Only for syslog it does not work.
any ideas, how to configure a vrf src interface for logging ?
actual config
int loopback 10
ip vrf red
ip address 1.1.1.253 255.255.255.255
# tftp packets where send from the vrf with src lo 10
ip tftp source-interface Loopback10
# logging packets where not sent from vrf, but with src lo 10
logging source-interface Loopback10
# snmp and ntp packets where send from vrf interface
snmp-server host 1.1.1.1 vrf red test
ntp server vrf red 1.1.1.1
thx
09-24-2005 06:13 PM
Not sure about ntp, but for snmp traps, you may use the "snmp-server trap-source" command
10-05-2005 01:39 AM
snmp works fine, I have the problem for the "syslog messages"
11-24-2006 07:57 AM
I've reached a similar problem. Have you find a solution for the described problem?
thx
11-30-2006 03:32 AM
I found no solution, sorry
