Community Member
MAB on switch Authenticates but drops traffic
I am implmenting Cisco ASC 5.3 and have configured MAB for non 802.1x devices. When I connect my host I see that on the ACS it passes authentication, the switch shows that it is auhtorised but when I show mac address on the port it says drop. When I look at the console logs I can see it is unable to add address (see below)
switch(config)#int f4/0/30
switch(config-if)#shut
switch(config-if)#no shut
switch(config-if)#
Mar 21 10:09:40 GMT: %LINK-5-CHANGED: Interface FastEthernet4/0/30, changed state to administratively down
switch(config-if)#
Mar 21 10:09:43 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/0/30, changed state to down
switch(config-if)#
Mar 21 10:16:27 GMT: %AUTHMGR-5-START: Starting 'mab' for client (0024.8c1e.36ee) on Interface Fa4/0/30 AuditSessionID AC1FFF11000000957F482268
Mar 21 10:16:27 GMT: %MAB-5-SUCCESS: Authentication successful for client (0024.8c1e.36ee) on Interface Fa4/0/30 AuditSessionID AC1FFF11000000957F482268
Mar 21 10:16:27 GMT: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (0024.8c1e.36ee) on Interface Fa4/0/30 AuditSessionID AC1FFF11000000957F482268
switch(config-if)#
Mar 21 10:16:27 GMT: %DOT1X_SWITCH-5-ERR_ADDING_ADDRESS: Unable to add address 0024.8c1e.36ee on Fa4/0/30 AuditSessionID AC1FFF11000000957F482268
Mar 21 10:16:27 GMT: %AUTHMGR-5-SECURITY_VIOLATION: Security violation on the interface Fa4/0/30, new MAC address (0024.8c1e.36ee) is seen.AuditSessionID  AC1FFF11000000957F482268
Mar 21 10:16:28 GMT: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (0024.8c1e.36ee) on Interface Fa4/0/30 AuditSessionID AC1FFF11000000957F482268
switch(config-if)#
Mar 21 10:16:29 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/0/30, changed state to up
Mar 21 10:16:30 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/0/30, changed state to up
sh mac address int f4/0/30
Vlan    Mac Address       Type        Ports
 214    0024.8c1e.36ee    DYNAMIC     Drop
my port configuration si
interface FastEthernet4/0/30
 description -==User Ports==-
 switchport access vlan 214
 switchport mode access
 switchport nonegotiate
 authentication event fail action next-method
 authentication host-mode multi-auth
 authentication order mab dot1x
 authentication priority dot1x mab
 authentication port-control auto
 authentication violation restrict
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
 spanning-tree bpduguard enable
end
Has anybody encountered an issue similar to this? I am connecting a laptop which has its mac address added to the internal hosts on the ACS
Anthony
Community Member
Hello, Please see the
Please see the following post it migh help.
https://supportforums.cisco.com/document/26336/dot1xswitch-5-erraddingaddress-error-message-appears-cisco-catalyst-3550-or-3750
If not please provide the IOS version, the kind of device you trying to authenticate, if a phone what OS is behind the phone. I used to work for TAC and in fact these cases are not easy solve.
Erick Delgado
Community Member
Did you find the solution?
Did you find the solution?   I am having the same issue.
Community Member
I left it with the customer
I left it with the customer to try on a different switch and still awaiting confirmation. I will post outcome when I hear back from them.
Error Message    DOT1X_SWITCH
Error Message    DOT1X_SWITCH-5-ERR_ADDING_ADDRESS: Unable to add address [enet] on
[chars] AuditSessionID [chars]
Explanation    The client MAC address could not be added to the MAC address table because the hardware memory is full or the address is a secure address on another port. This message might appear if 802.1x is enabled. [enet] is the client MAC address, the first [chars] is the interface, and the second [chars] is the session ID.
Recommended Action    If hardware memory is full, remove some of the dynamic MAC addresses. If the client address is on another port, remove it from that port.
372
