Need Help Configuring an 871 Router for IPSec VPN with SDM
I am setting up an 871 Router on my own for the very first time for a customer. I was able to get the initial set up of the static public IP address and DNS settings set properly and users are able to get out to the Internet. I am now in the process of configuring the router to be an IPSec VPN server so that remote users can access the network. However, as I mentioned, this is the first time I have setup a router. Every thing that I have found for configuration points to the 871 remoting to a VPN concentrator.
Can anyone point me in the right direction on what to do? I would like to use the SDM if possible since I do not want to interupt the use of the Internet for users.
If you need more information, I will be glad to provide it.
Mike
1 REPLY
Re: Need Help Configuring an 871 Router for IPSec VPN with SDM
235
