Community Member
pix 515 and group-policy
how many group-policy can I configure on PIx 515E with release 7.x?
Thanks in advance
B.
Re: pix 515 and group-policy
What are you warried about?
Community Member
The number of group-policy is important for me because I've many vpn-client sessions that refer to only one vpn-group.
By radius I authenticate the user and I send to pix the name of group policy that contains the specific address-pool and the split-tunneling acl.
In this way I can associate per-user the address-pool and the split-acl.
The best way would be to have only one group-policy and to send by radius the name of addrress pool and the name of split acl but the pix seems no support these parameters.
Thanks B
But why do you want to assign different IP Pools for 'each user'?
Farrukh
Community Member
I must assign a different pool address because in the second level firewall connected to the pix I have only IP address to identify the users
Well then you can use a DHCP server also (instead of AAA).
Farrukh
Community Member
I haven't a dhcp server and I wouldn't to set the pix as dhcp .
Well it should be at least as much as the 'No of VPN Tunnels' supported on the box.
Farrukh
213
