12-14-2011 05:30 AM - edited 02-21-2020 04:31 AM
Hi everyone ,
I am able to ping from outside to inside all ips , but there is no communication from inside and outside to DMZ .
I did debug icmp trace 255 and it gives below debug , anyone can guide me if i am doing any mistake here in config .
pixfirewall(config)# ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=74 seq=0 len=72
ICMP echo request untranslating OUTSIDE:131.1.23.10 to DMZ:192.168.10.10
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=74 seq=1 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=74 seq=2 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=74 seq=3 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=74 seq=4 len=72
DMZ>sh ip int br
Ethernet0/0 192.168.0.1 YES manual up up
Ethernet0/1 unassigned YES unset administratively down down
Ethernet0/2 unassigned YES unset administratively down down
Ethernet0/3 unassigned YES unset administratively down down
FastEthernet1/0 20.1.1.2 YES NVRAM administratively down down
Loopback0 192.168.10.10 YES manual up up
Loopback1 4.4.4.4 YES NVRAM up up
DMZ>
INSIDE-RTR>sh ip int br
Ethernet0/0 10.10.254.2 YES NVRAM up up
Ethernet0/1 unassigned YES NVRAM administratively down down
Ethernet0/2 unassigned YES NVRAM administratively down down
Ethernet0/3 unassigned YES NVRAM administratively down down
Loopback0 10.14.8.50 YES NVRAM up up
Loopback1 10.10.10.10 YES manual up up
INSIDE-RTR>
OUTSIDE>sh ip int br
Ethernet0/0 unassigned YES TFTP administratively down down
Ethernet0/1 131.1.23.1 YES NVRAM up up
Loopback0 5.5.5.5 YES manual up up
Loopback1 1.1.1.1 YES NVRAM up up
OUTSIDE>
pixfirewall# sh run
: Saved
PIX Version 7.2(4)
hostname pixfirewall
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
speed 100
duplex full
nameif INSIDE
security-level 100
ip address 10.10.254.1 255.255.255.0
interface Ethernet1
speed 100
duplex full
nameif OUTSIDE
security-level 0
ip address 131.1.23.2 255.255.255.0
interface Ethernet2
speed 100
duplex full
shutdown
no nameif
security-level 50
no ip address
interface Ethernet3
speed 100
duplex full
nameif DMZ
security-level 50
ip address 192.168.0.2 255.255.255.0
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
ftp mode passive
same-security-traffic permit intra-interface
access-list 101 extended permit ip any any log
access-list ACL-BW extended permit ip any any
access-list DMZtoINSIDE extended permit ip any any log
pager lines 24
logging buffered debugging
mtu INSIDE 1500
mtu OUTSIDE 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (OUTSIDE) 1 131.1.23.12-131.1.23.254
nat (INSIDE) 1 10.0.0.0 255.0.0.0
static (INSIDE,OUTSIDE) 131.1.23.11 10.14.8.50 netmask 255.255.255.255
static (INSIDE,DMZ) 192.168.11.11 10.10.10.10 netmask 255.255.255.255
static (DMZ,OUTSIDE) 131.1.23.10 192.168.10.10 netmask 255.255.255.255
access-group 101 in interface OUTSIDE
access-group DMZtoINSIDE in interface DMZ
route INSIDE 10.14.8.0 255.255.255.0 10.10.254.2 1
route INSIDE 10.10.10.0 255.255.255.0 10.10.254.2 1
route OUTSIDE 0.0.0.0 0.0.0.0 131.1.23.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
priority-queue OUTSIDE
class-map CLASS-BW
match access-list ACL-BW
class-map bw-limit1
policy-map POLICY-BW
class CLASS-BW
police output 8000 1000 conform-action drop
service-policy POLICY-BW interface OUTSIDE
prompt hostname context
Cryptochecksum:2544d2c2a04267b55ac2ae90ba42d40f
: end
thanks 4 reply
12-14-2011 10:22 PM
Hello Sagar,
1- Global (dmz) 1 interface
This will allow traffic from the inside to the DMZ because in order to allowt traffic from a higher to a lower security level interface you will need a NAT rule ( with nat control enabled)
2-Static (dmz,outside) xxxxx yyyyyy
In order to allow communication from a lower security level to a higher you need two things a bidirectional nat rule and an ACL applied to the lower security level interface.
I would like to see why this connection is not working:
So lets do a packet tracer
packet-tracer input outside icmp 131.1.23.1 8 0 131.1.23.10
Please provide output of the packet tracer
Please rate helpful posts.
Regards.
Julio
12-15-2011 12:25 AM
Hi Julio ,
Thnks 4 reply .
I added command #global (DMZ) 1 interface -------(even i m not able to understand the need of the command here as static nat is available )
later i did packet trace with below output , pls see if I m doing some mistake in configuration .
pixfirewall# packet-tracer input ouTSIDE icmp 131.1.23.1 8 0 131.1.23.10
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=0 seq=0 len=0
match ip DMZ host 192.168.10.10 OUTSIDE any
<--- More --->ICMP echo request untranslating OUTSIDE:131.1.23.10 to DMZ:192.168.10.10
static translation to 131.1.23.10
translate_hits = 0, untranslate_hits = 3
NAT divert to egress interface DMZ
Untranslate 131.1.23.10/0 to 192.168.10.10/0 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 437, packet dispatched to next module
Result:
input-interface: OUTSIDE
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: drop
Drop-reason: (no-adjacency) No valid adjacency
pixfirewall#
Thanks 4 reply
12-15-2011 09:08 AM
Hello Sagar,
The Global (dmz) is for the users on the inside to get natted to the DMZ interface, but if you just want to get to the DMZ from 10.10.10.10 you already have the static as you said so you do not need the global.
Here is the problem we are seeing when the connection is made from the outside to the DMZ:
This counter is incremented when the security appliance has tried to obtain an adjacency and could not obtain the MAC address for the next hop. The packet is dropped.
Recommendation: Configure a capture for this drop reason and check if a host with the specified destination address exists on the connected network or is routable from the security appliance.
On the packet tracer we can see that the traffic is hitting the right policies ( NAT statements, Access-list, Inspection)
I would like to see if you can perform the following tasks:
1-Can you ping 131.1.23.1 from the ASA
2-Can you ping 192.168.10.10 from the ASA.
Also lets create the following capture and let me know the outputs you get:
access-list capout permit icmp 131.1.23.1 255.255.255.255 host 131.1.23.10
access-list capout permit icmp host 131.1.23.10 131.1.23.1 255.255.255.255
access-list capdmz permit icmp host 131.1.23.1 host 192.168.10.10
access-list capdmz permit icmp host 192.168.10.10 host 131.1.23.1
capture capdmz access-list capdmz interface dmz
capture capout access-list capout interface outside
Please rate helpful posts,
Julio
12-16-2011 06:20 AM
Hi Julio ,
Thanks 4 your reply .
Here are the outputs u asked me -
1-Can you ping 131.1.23.1 from the ASA ----yes pinging
pixfirewall# ping 131.1.23.1
Sending 5, 100-byte ICMP Echos to 131.1.23.1, timeout is 2 seconds:
ICMP echo request from 131.1.23.2 to 131.1.23.1 ID=4388 seq=36579 len=72
!ICMP echo reply from 131.1.23.1 to 131.1.23.2 ID=4388 seq=36579 len=72
2-Can you ping 192.168.10.10 from the ASA. ---not reachable
pixfirewall# ping 192.168.10.10
Sending 5, 100-byte ICMP Echos to 192.168.10.10, timeout is 2 seconds:
ICMP echo request from 131.1.23.2 to 192.168.10.10 ID=4388 seq=16281 len=72
?ICMP echo request from 131.1.23.2 to 192.168.10.10 ID=4388 seq=16281 len=72
Success rate is 0 percent (0/5)
pixfirewall#
I have applied all below captures ----->>
pixfirewall# clear access-list capout counters
pixfirewall#
pixfirewall# clear access-list capdmz counters
pixfirewall#
pixfirewall# clear access-list 101 counters
pixfirewall#
pixfirewall# clear access-list DMZtoINSIDE counters
pixfirewall#
---then ---->
OUTSIDE#ping 131.1.23.10
Sending 5, 100-byte ICMP Echos to 131.1.23.10, timeout is 2 seconds:
OUTSIDE#
pixfirewall# ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=77 seq=0 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=77 seq=1 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=77 seq=2 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=77 seq=3 len=72
ICMP echo request from OUTSIDE:131.1.23.1 to DMZ:131.1.23.10 ID=77 seq=4 len=72
pixfirewall#
ICMP echo request from 131.1.23.2 to 192.168.10.10 ID=4388 seq=18641 len=72
?ICMP echo request from 131.1.23.2 to 192.168.10.10 ID=4388 seq=18641 len=72
pixfirewall#
pixfirewall#
ICMP echo request from 131.1.23.2 to 131.1.23.1 ID=4388 seq=44599 len=72
!ICMP echo reply from 131.1.23.1 to 131.1.23.2 ID=4388 seq=44599 len=72
!ICMP echo request from 131.1.23.2 to 131.1.23.1 ID=4388 seq=44599 len=72
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/50/90 ms
pixfirewall# ICMP echo reply from 131.1.23.1 to 131.1.23.2 ID=4388 seq=44599 len=72
pixfirewall#
pixfirewall#
pixfirewall# sh access-list
access-list cached ACL log flows: total 1, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list 101; 1 elements
access-list 101 line 1 extended permit ip any any log informational interval 300 (hitcnt=1) 0x28676dfa
access-list ACL-BW; 1 elements
access-list ACL-BW line 1 extended permit ip any any (hitcnt=156) 0xfa95bcad
access-list DMZtoINSIDE; 1 elements
access-list DMZtoINSIDE line 1 extended permit ip any any log informational interval 300 (hitcnt=0) 0xf5a55e4b
access-list capout; 2 elements
access-list capout line 1 extended permit icmp host 131.1.23.1 host 131.1.23.10 (hitcnt=5) 0xfb220e61
access-list capout line 2 extended permit icmp host 131.1.23.10 host 131.1.23.1 (hitcnt=0) 0xda226f3d
access-list capdmz; 2 elements
access-list capdmz line 1 extended permit icmp host 131.1.23.1 host 192.168.10.10 (hitcnt=0) 0xa133807b
access-list capdmz line 2 extended permit icmp host 192.168.10.10 host 131.1.23.1 (hitcnt=0) 0x99b84706
pixfirewall#
Thanks 4 your reply again
12-16-2011 06:55 AM
Hello Sagar,
You did not understand the purpose of the capture, you had to make the connection from 131.1.23.1 to 131.1.23.10 in order to get the packets on the capture.
But do not worry at this time I think we already saw the problem. The ASA does not know how to get to 192.168.10.10.
you need the following command:
route dmz 192.168.10.10 255.255.255.0 192.168.0.1
Julio
12-16-2011 09:21 AM
Hi Julio ,
Thanks 4 reply
I added route for 192.168.10.10 in pix but still I m not able to ping 131.1.23.10 .
OUTSIDE#
OUTSIDE#ping 131.1.23.10 source 131.1.23.1
Packet sent with a source address of 131.1.23.1
OUTSIDE#
ACL captures======>
alert-interval 300
pixfirewall#
Please let me know if I am doing anyting wrong here
Thanks again
12-16-2011 09:40 AM
Hello Sagar,
Just to see if we are on the same page you are trying to ping from the outside router (131.1.23.1) to the DMZ server Public IP address (131.1.23.10) right?
So the Pix should start proxy-arping that Ip address ( 131.1.23.10)
The configuration you need in order to allow this will be:
static (dmz,outside) 131.1.23.10 192.168.10.10
access-list 101 permit ip any host 131.1.23.10
access-group 101 in interface outside
route dmz 192.168.10.0 255.255.255.0 192.168.0.1
Can you check if you can have the same configuration?
Also Can you ping 192.168.10.10 now? If you cannot do it there is something wrong with the layer 3 device on the DMZ network because its blocking the ICMP request.
Please let me know this two things?
Julio
12-21-2011 04:10 AM
Hey Julio ,
I am doing exactly the same , I am using GNS3 and trying to implement it .
Thanks 4 reply
12-21-2011 09:18 AM
Hello Sagar,
Sure, let me know the result.
Julio
