Port channel issue in ASA
We have two Cisco ASA 55XX Firewalls and both are in HA (Active/Standy). Two ports from each Firewall is connecting two ports of Nexus 5K Switch and running port channel between Firewall & Nexus Switch and port-channel is UP. And Switches having back to back connection with allowed all VLAN trunk port.
FW01 ----------------- SW01 (Two ports with Port channel)
FW02 ----------------- SW02 (Two ports with Port channel)
I have VLAN 10 with IP Subnet 10.10.10.0/28
SW01 : 10.10.10.2
SW02 : 10.10.10.3
HSRP IP : 10.10.10.1
FWs :  10.10.10.4 & 10.10.10.5
Firewall Default Gateway : 10.10.10.1
Problem : I am not able Ping Firewall IPs from Nexus Switches. When I checked ARP table in Nexus Switch; I have observed that Firealls two IPs having same MAC address; when I checked that MAC address in the Firewall; that MAC address is Port channel interface MAC address.
This is issue (two IPs learing same MAC address) from ASA.
How to fix this issue ?
Venkat
667
