Port security configured on two ports, in same vlan, but no SHUTDOWN when change computer in those 2 ports.......
I set up my switch, the port security is activated, but when i have 2 ports configured in same vlan, when changing the computers conected in those ports between them, the ports are not going in shutdown, only discard packets.
How can i configure to shutdown the port when another mac is detected? even is in the same vlan.
Please Post your config
test#sh runconfig-file
test#sh run
config-file-header
test
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passpharse control unrestricted
no ssd file integrity control
vlan database
vlan 2-3
exit
bonjour interface range vlan 1
hostname test
interface fastethernet2
   port security discard-shutdown
   switchport mode access
   switchport access vlan 2
interface fastethernet3
exit
mac address-table static 00:00:03:45:56 vlan 2 interface fastethernet2 secure
mac address-table static 00:00:bc:f2:01:b4 vlan 2 interface fastethernet3 secure
this is my running config
if i put the mac from fa3 in fa2 port, the port is not going in shutdown, only discard the packets, but if i change the vlan from 2 to 3 , the port wil be shutdown.
I'm afraid that this isn't
I'm afraid that this isn't quite what port-security does.  Port-security will not change the configuration of your switch to add the "shutdown" command into the running configuration of that interface.
Rather, port-security places the port into a disabled state.  As you said, the switch will begin dropping frames that it receives on that port.  There is no configuration setting that you could put in place to actually shut the port down.
What is your end goal?  Why do you want the port to actually shut down rather than discard frames?
when port security is enable,
when port security is enable, and if you set in case of violation, to shutdown the port, the port is going off when another mac is detected.
Silver
Hello dani,I would configure
Hello dani,
I would configure the MAC address statically by using switchport port-security mac-address XXXX, this won't care about which vlan it's in.
David
"Don't think you are, know you are"
-Morpheus
My switch is an SRW248G4-K9
My switch is an SRW248G4-K9-EU.  the cli commands are not the same as a cisco Catalyst 3560 switch.
there are 3 options when configure port security: Discard, Forward and DIscard-Shutdown.
Acalderone, when the port security is configured on a switch with IOS, the ports are going down when another mac is detected on port, even if the port is configured in the same vlan.
my switch shut down the port if if is in another vlan. but when are in the same vlan, the ports only discard traffic.
thank you guys for help
870
