07-20-2012 05:09 AM - edited 02-21-2020 04:41 AM
i have the asa5505 with asa8.4.5 and asdm 6.4.2. my asa work like site to site vpn with the other asa5505. i would be love that monitoring status of VPN. i enabled on asa logging, i puted address of smtp server, receipent email, source email, the problem is because my smtp server require authentication, TLS. how set configuration on asa5505?
configuration of logging for send notification on email:
smtps
port 587
server smtp.gmail.com
default-group-policy DfltGrpPolicy
authentication aaa mailhost
smtp-server 173.194.70.108
07-20-2012 10:10 AM
Hi Bro
I don't know much about TLS but I do know the commands shown below will work. I've done this too many times to know for sure, it will work like a charm. Just ensure your EMail Server supports Mail Relay.
logging enable
logging timestamp
logging list TEST level alerts
logging mail TEST
logging from-address FW01@cisco.com
logging recipient-address johnniewalker@cisco.com level alerts
logging device-id hostname
smtp-server 192.168.10.1
If you need more information on this, you could also refer to this URL https://supportforums.cisco.com/thread/2014922
P/S: If you think this comment is useful, please do rate them nicely :-)
07-22-2012 11:55 PM
yes, bro but my smtp server require the authentication and the server use tls? how do i set this configuration on asa5505
07-25-2012 03:15 AM
Hi Bro
Have you tried my sugegestion? If it doesn't work, then I believe Cisco ASA FW can't do this at all but if it does, well and good. Give it a try. This is because I have done this with many EMail Servers in the market, and I have not encountered any issues. Give it a try, and let me know if it works or don't
logging enable
logging timestamp
logging list TEST level 7
logging mail TEST
logging recipient-address johnniewalker@cisco.com level 7
07-25-2012 04:07 AM
it doesn't work. my smtp server want authentication.
07-25-2012 04:18 AM
How do you know the smtp server wants authentication? Are you seeing any error logs that states this?
07-25-2012 04:23 AM
my mail account for outlook is configured with authentication for this smtp server. when i disable the authentication i can't send e-mail from outlook
07-25-2012 04:35 AM
Yes, I know your client email accont needs authentication but not for the FW. As long as the FW supported email relay, this is good enough. Have you tried the commands that I've proposed to you. I can't be wrong as I have done this too many times for many large corporations.
07-25-2012 04:42 AM
yes, i used the commands that you uswd but i can't send mail from asa5505
07-25-2012 06:13 AM
Can you paste your complete "show run logging" and "show run | i smtp" here?
07-25-2012 06:30 AM
Result of the command: "show run"
: Saved
ASA Version 8.2(1)
hostname ciscoasa
enable password csq7sfr0bQJqMGET encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.5.0 PALATA
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.17 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.13.74.33 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
object-group service DM_INLINE_SERVICE_1
service-object ip
service-object tcp
service-object icmp echo
service-object icmp echo-reply
service-object tcp eq domain
service-object tcp eq ldap
service-object tcp eq smtp
object-group service DM_INLINE_SERVICE_2
service-object ip
service-object tcp eq www
service-object tcp eq https
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_2 192.168.0.0 255.255.255.0 any
access-list inside_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 PALATA 255.255.255.0
access-list outside_2_cryptomap extended permit ip 192.168.0.0 255.255.255.0 PALATA 255.255.255.0
pager lines 24
logging enable
logging asdm informational
logging mail errors
logging from-address xxx@gmail.com
logging recipient-address xxx@gmail.com level errors
logging class auth mail errors
logging class session mail errors
logging class vpn mail debugging
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.0.0 255.255.255.0
static (inside,outside) 10.13.74.35 192.168.0.22 netmask 255.255.255.255
static (inside,outside) 10.13.74.34 192.168.0.20 netmask 255.255.255.255 dns
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.13.74.1 1
route inside 0.0.0.0 0.0.0.0 192.168.0.17 tunneled
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server smtp.gmail.com protocol http-form
aaa-server smtp.gmail.com (outside) host 173.194.70.108
user-parameter xxx@gmail.com
password-parameter goran1975
aaa authentication telnet console LOCAL
http server enable
http 10.13.74.0 255.255.255.0 outside
http 192.168.0.0 255.255.255.0 inside
http 10.15.100.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
virtual telnet 192.168.0.53
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_2_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 10.15.100.15
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username xxx password AojCAMO/soZo8W.W encrypted privilege 15
username xxx@gmail.com password q4TBYQT9hrhqEJg7 encrypted
tunnel-group 10.15.100.15 type ipsec-l2l
tunnel-group 10.15.100.15 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
service-policy global_policy global
smtps
port 587
prompt hostname context
Cryptochecksum:15217a375a1ed15f915c173809a24a77
: end
07-25-2012 06:56 AM
Add These Lines
logging mail debug
logging from-address ciscoasa@fw.com
logging recipient-address ???@gmail.com level debug
smtp-server 173.194.79.109 // smtp.gmail.com
Remove These Lines
no smtp-server 173.194.70.108
no logging class auth mail errors
no logging class session mail errors
no logging class vpn mail debugging
no aaa-server smtp.gmail.com protocol http-form
no aaa-server smtp.gmail.com (outside) host 173.194.70.108
no user-parameter xxx@gmail.com
no password-parameter goran1975
no username xxx@gmail.com password q4TBYQT9hrhqEJg7 encrypted
no smtps
no port 587
no server smtp.gmail.com
no authentication aaa mailhost
07-25-2012 07:17 AM
again, nothing
07-25-2012 07:20 AM
Your config is good, my guess is the smtp-server that you're pointing to doesn't support SMTP Relay. Could you try few more other public smtp servers, if any luck :-)
07-25-2012 11:47 PM
can you give to me any public smtp server?
