RCP issue-LMS 2.5
johnjamesraj
I am installing and configuring LMS 2.5 on solaris 2.8 paltform. I am facing problem with RCP image transfer in all my Cisco devices. I configured the router with the following commands:
username xxxx password xxxx
ip rcmd rcp-enable
ip rcmd remote-host cimadmin 192.168.253.15 cimadmin enable
ip rcmd remote-username cimadmin
ip rcmd source-interface VLAN1
no ip rcmd domain-lookup
and I enabled rcp in the OS and Ciscoworks as per the Cisco documentation.
I am getting the following error while doing image transfer:
Error message in Job Result is as follows:
SWIM1124: Failed to copy the image from Flash due to the reason - copyInvalidOperation : command invalid or command-protocol-device combination unsupported.
Retry the operation. If the problem persists, check the Bug Toolkit application for any known issues on the running image version.
Image Import Operation Failed
Following is the error message from dmgtd.log :
Jan 11 15:02:50 cimxs001 dmgt[22831]: [ID 505812 local0.warning] #2053:TYPE=WARN
ING:An application that is not registered sent a status message SWIM to the daemon manager. The message was ignored.
Jan 11 15:06:07 cimxs001 SQLAnywhere(rmengeng): [ID 702911 local0.notice] Connection terminated abnormally
Jan 11 15:06:07 cimxs001 last message repeated 1 time
Jan 11 15:06:07 cimxs001 SQLAnywhere(cmfeng): [ID 702911 local0.notice] Connection terminated abnormally
Jan 11 15:06:08 cimxs001 dmgt[22831]: [ID 922430 local0.info] #3011:TYPE=INFO:Application "1236" unregistered.
Attaching the Complete JobResult,dmgtd.log and swim_debug.log
Note: 1.Configuration Management using RCP is working fine 2.Image transfer using TFTP is working fine
I have to for for RCP as per the decision made by design team..Please help me out
johnjamesraj
Is there anyone using RCP for image transfer in this world??? Please share your experience...
