Removal of corrupt group policy
I have a group policy that I use for SSL VPN for some of my users. It has some machine characters after the group name. I have tried unsuccessfully to remove the group policy, but keep getting a "group XXXX does not exist" error. I have tried from the ASA and from the command line.
I attached a screen shot of the corrupt pool.
Thoughts and/or suggestions would be welcome
Re: Removal of corrupt group policy
How are you trying to remove that line? Have you tried using ASDM to see if it shows that part of the config?
Tried both from the ASDM and a copy and past from the CLI. FWIW, the garbage at the end of the line appears different in ASDM than it does in the CLI.
Go ahead and do a "show run all group-policy" wait till you get the output of that specific group policy, then see if you can just copy paste that name without the trash and issue a "clear config group-policy XXXXXXXXXX"
Thanks I will let you know what happens.
Well I tried that and I received the following error:
ERROR: group-policy XXXX does not exist
Next idea?
David
384
