08-04-2006 05:57 AM - edited 02-21-2020 01:05 AM
I am attempting to provision a Cisco 851 with 12.4(4)T3 using SDM. I do alright until I add and Easy VPN Server.
At that time when the route-maps are added and the tool generates the route-maps associated with the dynamic and static NAT's in place things go south.
The network is small with one MS Server that runs File & Print along with Exchange. There is also a machine with SFTP server loaded on it.
I am hoping someone can assist me with the ACL's I have added part of the configuration
TIA
Solved! Go to Solution.
08-05-2006 04:53 PM
What error did u get on the VPN Client? Are you sure you always get the same IP and subnet on your Dialer?
08-04-2006 02:47 PM
08-04-2006 03:11 PM
Thanks I will I will have some questions after I test this
Most of this was generated with the SDM tool but it is obvious I made some wrong entries TIA
08-04-2006 09:32 PM
Usually I don't use any graphical interface for configuring and even troubleshooting Cisco. ASDM is a good tool but it does't really let you what is going in the background of the config. However, do command line config helps you really understand what is going on and also to do some enhancements such as route summarization etc...
08-05-2006 04:17 AM
I used to work for a company that had 28 CCIE's
All of them CLI users.....I understand.
08-05-2006 09:28 AM
08-05-2006 04:53 PM
08-05-2006 05:31 PM
Mohamad
The number was 412 I do not remember the exact wording sorry something like connection cancelled/closed by client
The IP is a static handed out by AT&T/SBC....
08-05-2006 11:07 PM
When I sent you the config the KEY under the vpn client configuration was empty. I don't know if you uploaded the config directly without setting the KEY on the config.
Make sure in the config and on the vpn client the group key is correct!
Let me know the progress,
08-07-2006 08:30 AM
Mohamad
I will try the configuration this evening Monday EDT
Thomas
08-07-2006 04:23 PM
Mohamad
The problem was with trying to use RADIUS The config was missing some config lines I changed it to authenticate locally and was able to establish connection
Thank you for assistance
08-07-2006 05:40 PM
Hello Thomas,
Glad to know that things are working as you wish.
