Community Member
Several peers connecting to single interface
I wonder if anyone can help me please. I am setting up vpn tunnels between my site and 3 other sites (there is no connectivity required between these 3 sites).
I am using a Cisco 7301 as my endpoint and have a single IP address that all three sites have to use as their peer address.
Please help with the configuration of this, I am told it is possible to configure this but would like some assistance, any sample configs or pointers in the right direction will be gratefully received.
Cheers,
Martha.
Re: Several peers connecting to single interface
Hi Martha,
Here is a sample config for a lan to lan between 2 routers each will only have a single peer, not quite what you are looking for I know. The keypoint is that the only thing to do is to create new crypto maps, with it's interesting traffic and new isakmp keys
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_example09186a008073e078.shtml
What I mean is that you configure a single tunnel, then you go ahead and copy that into a notepad to adjust this settings to the new peers (peer address, interesting traffic match address, transform set) and use the same crypto map name with a different sequence number. This will allow you to add multiple tunnels to a single router.
Community Member
Thanks for your response.
I will look at the link and try to create my own config from it. I just wanted to make sure it was possible to do this with no adverse effects.
Cheers.
164
