Show conn state and fix-ups
Can the show conn state command be used to monitor the connections for fix-up protocols?
1 REPLY
Silver
Re: Show conn state and fix-ups
Use the show port status command to display port status information.
show port status [mod_num[/port_num]]
Syntax Description
mod_num
(Optional) Number of the module.
/port_num
(Optional) Number of the port on the module.
This example shows how to display port status information for all ports:
Console> show port status
Port Name Status Vlan Level Duplex Speed Type
1/1 connected 523 normal half 100 100BaseTX
1/2 notconnect 1 normal half 100 100BaseTX
2/1 connected trunk normal half 400 Route Switch
3/1 notconnect trunk normal full 155 OC3 MMF ATM
5/1 notconnect 1 normal half 100 FDDI
5/2 notconnect 1 normal half 100 FDDI
266
