Shutdown unused ports at the switches
Dears,
Can I shutdown all unused ports at Cisco switches by Netconfig or other tool at Cisco Works managment too?I have 300 LAN switches and I need to block all unused ports automatically.
Many thanks.
Hall of Fame Super Gold
Re: Shutdown unused ports at the switches
You may want to use EEM scripts.  Here are some examples:
https://supportforums.cisco.com/thread/176341
Please don't forget to rate our posts.  Thanks.
Thank you for  the prompt feedback, but how I
can run  this script at the switches? Can I send it through TFT
P?What is the last version of this EEM scripts I can use as I can see alot of them posted.
Many thanks.
3398
