Community Member
site to site vpn - help
I've configured a site to site vpn between two 2811 routers, one local and another one remote.
I need to know if a PC conected to the remote LAN (192.168.10.0) can connect to the local LAN (192.168.2.0).
These are the routers configurations,
Local:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxx address xx.xx.xx.xx
crypto isakmp client configuration group xxxxxx
key xxxxxx
pool ippool
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
reverse-route
crypto map IPSEC_VPN isakmp authorization list groupauthor
crypto map IPSEC_VPN client configuration address respond
crypto map IPSEC_VPN 3 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set ESP-3DES-SHA
match address 103
crypto map IPSEC_VPN 10 ipsec-isakmp dynamic dynmap
interface Tunnel1
ip address 10.1.1.10 255.255.255.252
keepalive 10 3
tunnel source FastEthernet0/0
tunnel destination xx.xx.xx.xx
interface Loopback0
ip address 10.11.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description Interface WAN
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip access-group 14 out
ip nat outside
load-interval 30
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
load-interval 30
ip local pool ippool 192.168.2.11 192.168.2.15
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
ip route 192.168.10.1 255.255.255.0 10.1.1.9
ip http server
no ip http secure-server
ip nat inside source route-map primary interface FastEthernet0/0 overload
access-list 14 permit any
access-list 102 deny ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
access-list 103 permit gre host xxx.xxx.xxx.xxx host xxx.xxx.xxx.xxx
route-map primary permit 10
match ip address 102
match interface FastEthernet0/0
Remote:
encr 3des
group 2
crypto isakmp key xxxx address xxx.xxx.xxx.xxx
description IPSEC VPN
set peer xxx.xxx.xxx.xxx
match address 103
interface Tunnel3
description vpn tunnel
ip address 10.1.1.9 255.255.255.252
ip nat inside
keepalive 10 3
tunnel source Vlan1
tunnel destination xxx.xxx.xxx.xxx
interface Vlan1
description Local HQ LAN
ip address 192.168.10.1 255.255.255.0
ip nat outside
ip route 192.168.2.0 255.255.255.0 10.1.1.10
ip http server
ip http authentication local
Please, could anybody help me?
Thanks in advance.
Regards.
140
