SSLVPN and routable IP addresses
I'm in the process of first time configuration of ASA 5510 using ASA 7.2(2) and ASDM 5.2(2). The Command Line Reference manual (7.2(2)) indicates NAT and PAT are features not supported with WEBVPN.
Does that mean that the appliance must allocate routable IP address to each active WEBVPN connection?
Thanks for the clarification.'
Silver
Re: SSLVPN and routable IP addresses
All webvpn users will connect to a single public ip of your ASA device, your outside interface basically.
Links helpful in configuring http://www.cisco.com/en/US/products/ps6121/products_user_guide_chapter09186a00806a2f4a.html
I have added a basic config that i have done as a part of my testing. Hopefull it helps you.
Cheers
Hoogen
Hoogen:
Thanks for the reply and for the link.
The section entitled "Understanding Features Not Supported for WebVPN" in the Command Line Configuration Guide 7.2.2 is confusing on this point.
The config file is very helpful for comparison. Thank you!
115
