Hi all. I'm pretty new to Cisco, and need to setup VPN access on a newly purchased 1811w router. Basically I need a setup where company employees can access their work desktop from home.
I have followed the instructions found here:
http://cisco.com/en/US/docs/routers/access/1800/1801/software/configuration/guide/vpnezvpn.html
and after following the instructions, I have the following config file (see attached).
Currently, when I issue the following command in the CLI: "show crypto ipsec client ezvpn", I get the following reply:
Eazy VPN Remote Phase: 6
Tunnel Name: ezvpnclient
Inside interface list:
Outside interface list: FastEthernet0
Current State: IDLE
Last Event: CRYPTO_SS_UNUSED
Save Password: Disallowed
Current EzVPN Peer: 10.10.20.5
My question(s) is - Does the config look like it is setup correctly, and if it does how do I test it (I've never used a VPN before.)
Thanks for the help.
