Using SNMP to monitor DMVPN NHRP
Are there any SNMP OIDs for monitoring dynamic DMVPN NHRP entries? I'd like to poll my hub router for a list of active DMVPN spokes, and NHRP seems like the best thing to check, but I can't find any MIBs for NHRP outside of the Frame Relay context.
Thanks!
-Mason
Bronze
Re: Using SNMP to monitor DMVPN NHRP
Thanks for the link, but could you be a bit more specific about what it shows? I've searched through these release notes for "snmp", "nhrp", and "dmvpn" but didn't find what I was looking for.
-Mason
I use these OID for my DMVPN query.
***HUB***
Active IKE sessions (count)
get .1.3.6.1.4.1.9.9.171.1.2.1.1.0
Active IPSec sessions (count)
get .1.3.6.1.4.1.9.9.171.1.3.1.1.0
IKE Peer's IP address (list)
walk .1.3.6.1.4.1.9.9.171.1.2.2.1.7.0
***SPOKE***
IKE History (ID)
walk .1.3.6.1.4.1.9.9.171.1.4.2.1.1.8
IKE History (reason based on ID)
walk .1.3.6.1.4.1.9.9.171.1.5.2.1.1.2
I don't know if it's exactly what you want. But if it's not, you can walk the cisco mib 1.3.6.1.4.1.9 in a text file and grab what you want. It's like this that I've found my OID
Enjoy :)
Thanks for the info. I'm sure this is what I'm looking for, but my router isn't responding to anything under the .171 OID. Doing an snmpwalk against 1.3.6.1.4.1.9.9, it jumps from 1.3.6.1.4.1.9.9.168 to 1.3.6.1.4.1.9.9.176. I'm running 12.4(9)T Advanced Security. What version are you running that has this MIB available? Or do I need to adjust the snmp-server views or something? I've never done that before, but this would be a good reason to try it out.
Thanks!
-Mason
I use 12.3(11)T6 Advanced Security on my 3825 and 831 routers.
Even if you adjust the setting that you want, if you snmp walk skip the .171 OID, you wont be able to have it, I think :(. You need to use another IOS version.
1608
