06-05-2007 11:34 AM - edited 02-21-2020 01:33 AM
I am having some issues getting VMS 2.3 installed. I know it is a dated product, but I want to utilize some of the other features it provides. After installation, the web access/log in just doesn't work. It looks like the syslog and TFTP daemons are running, I just can not log into it (no screen).
New Install, I can mess with any setting,
Mike
06-11-2007 12:53 PM
On what operating system platform did you install VMS ?
06-11-2007 06:18 PM
What URL are you using to try and access the server? What error message did you received, if any?
06-12-2007 07:59 AM
