VPN client to PIX works with RTC but not with ADSL
I use VPN client 4.01 to PIX 515E
On remote computer, I manage to set up the vpn and work with it using RTC dialup connection.
On the same computer, when I use a DSL connection, nothing works. I can conenct the VPN but I'm unable to ping or traceroute the remote devices.
Could anyone help ?
Silver
Re: VPN client to PIX works with RTC but not with ADSL
Problems encountered after the tunnel sets up properly have nothing to do with the process of setting up the VPN. These are discussed in the doc 'Troubleshooting Microsoft Network Neighborhood After Establishing a VPN Tunnel With the Cisco VPN Client' at http://www.cisco.com/warp/public/471/vpn-net-hood.html.
Yes, I read this article...
But there is a little difference here..
On the same computer, I manage to ping and log on remote devices throught the vpn when I use a basic RTC (dial-up) connection. The problem occurs when I use a DSL connection.
206
