VPN Client v4.8.02.0010 will not connect in Vista Business
Hi, this is my first time using this forum, so I hope this works.
I am using the following:
OS - Vista Business
VPN Client - Cisco VPN Client v4.8.02.0010
A number of my customers are getting the error "Secure VPN Connection terminated locally by the client. Reason 412: The remote peer is no longer responding." I have tried other versions of VPN Client but to no avail. I have tried the VPN with the firewall completely off and with the firewall on and specific TCP/UDP ports open. If I use the same version of VPN client in XP Pro, it works like a dream. Has anyone else had this problem? Any ideas?
Re: VPN Client v4.8.02.0010 will not connect in Vista Business
The VPN Client for vista is still a BETA release and is provided for testing purpose.
A guy from the TAC told me they should have a working client in march but no guaranty.
BTW, there is a new BETA release, version 5.0
Thanks for the quick reply. I having problems finding the v5.0 Beta release for VPN Client. Do you have a link for it?
You have to get it from cisco using your CCO account.
158
