WebVPN ssh-plugin doesn't work
seibertmedia
hello,
i've installed the ssh-Plugin ssh-plugin.080430.jar into our Cisco ASA 5510 Software 8.0(4).
I've created an Entry in the Webtype ACL list and in the Bookmark List. When i connect to the ssl-VPN, i can start the ssh-Java-Aplett and enter username and Password. But then happens nothing. It says "Connected to 192.168,0.5 ssh" "online" the console-window stays black. I've started tcpdump on the ssh-server and it sees no packet on the ssh-port. Is there anything else i have to configure to get this work?
thanks for your answers.
seibertmedia
Ok, I've found the solution:
At the acl-list, i can't use the url filter, i have filter on host and service:
Host: 192.168.0.5
Service: ssh
now it works. But other than documented by cisco, it only works with ssh protocol Version 2.
Hi Seibertmedia,
Could you please explain your solution with commands? We have got the same issue now with ASA 8.4.
saif
