cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
Estamos finalizando el lanzamiento de la nueva comunidad, debido a ello usted podrá experimentar lentitud en los tiempos de carga de las páginas, así como errores e inconsistencias menores. Le pedimos paciencia mientras finalizamos el proceso. Gracias.
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
ACS Browser Problem
We have a problem with the cisco ACS, we wanted to open the ACS with a browser Internet Explorer but we dont have all the buttons and options of the ACS. We have checked tha we opened with IE versión 11, the latest. Then we opened the ACS with a browser IE versión 8 amd we didn`t have this problem. The costumer must work with IE 11 and they wanted a solution with this problem with incompatibility, how can we fix this problem?
  • Seguridad
2 RESPUESTAS
In my experience, I have updated with the last patch to Cisco ACS and use Firefox last version without any problem.
I dot recommend use chrome browser, it may happen that policies are deleted.
regards
Hi, which version of ACS do
Hi, which version of ACS do you have? I am using ACS 5.8 and I work with IE version 11 without any problem.
Check the link to find compatibility information for  ACS :
http://www.cisco.com/c/en/us/support/security/secure-access-control-system/products-device-support-tables-list.html
Lp
20
Visitas
ÚTIL
Respuestas
