cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
No puedo conectar con SSM 10
Buenos días,
no puedo conectarme al AIP-SSM 10 en mi ASA 5520 a traves de ASDM (solo por CLI) Cuando lo intento aparece el siguiente mensaje: "Error loading sensor". Mi dirección ip es la 16.3.40.52. Otra cosa que me resulta muy extraña es no ver el modulo a traves de ASDM > Device Information. Adjunto configuracion y version de software. ¿Alguna idea sobre como solucionarlo?  Gracias
ASA5520ERA# sh ver
Cisco Adaptive Security Appliance Software Version 8.0(4)39
Device Manager Version 6.1(5)57
Compiled on Wed 01-Jul-09 17:24 by builders
System image file is "disk0:/asa804-39-k8.bin"
Config file at boot was "startup-config"
ASA5520ERA# session 1
Opening command session with slot 1.
Connected to slot 1. Escape character sequence is 'CTRL-^X'.
MODULO ANTI-INTRUSION
login: user
Password:
***NOTICE***
This product contains cryptographic features and is subject to United States
and local country laws governing import, export, transfer and use. Delivery
of Cisco cryptographic products does not imply third-party authority to import,
export, distribute or use encryption. Importers, exporters, distributors and
users are responsible for compliance with U.S. and local country laws. By using
this product you agree to comply with applicable laws and regulations. If you
are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
***LICENSE NOTICE***
There is no license key installed on the SSM-IPS10.
The system will continue to operate with the currently installed
signature set.  A valid license must be obtained in order to apply
signature updates.  Please go to http://www.cisco.com/go/license
to obtain a new license or install a license.
IPS_5520_ERA#
IPS_5520_ERA#  sh configuration
! Current configuration last modified Thu Jun 07 03:33:02 2012
! Version 6.0(4)
! Host:
!     Realm Keys          key1.0
! Signature Definition:
!     Signature Update    S317.0   2008-02-13
!     Virus Update        V1.2     2005-11-24
service interface
physical-interfaces GigabitEthernet0/1
description Principal sensing interface
exit
exit
service authentication
exit
service event-action-rules rules0
exit
service host
network-settings
host-ip 172.29.0.2/30,172.29.0.1
host-name IPS_5520_ERA
telnet-option disabled
access-list 16.0.0.0/24
access-list 16.3.0.0/16
access-list 172.19.6.253/32
access-list 172.19.6.254/32
access-list 172.29.0.1/32
login-banner-text  MODULE ANTI-INTRUSION
exit
time-zone-settings
offset 60
standard-time-zone-name GMT+01:00
exit
ntp-option enabled
ntp-keys 1 md5-key yellow
ntp-servers 172.29.0.1 key-id 1
exit
summertime-option recurring
summertime-zone-name GMT+01:00
start-summertime
week-of-month last
exit
end-summertime
month october
week-of-month last
exit
exit
exit
service logger
exit
service network-access
exit
service notification
trap-destinations 172.18.1.1
trap-community-name ROTom01
trap-port 162
exit
enable-notifications true
read-only-community ROTom01
system-location XXXXX,XX
system-contact XXXXXXXXX
exit
service signature-definition sig0
signatures 2004 0
event-counter
event-count 10
exit
status
enabled false
exit
exit
signatures 7000 0
status
enabled false
exit
exit
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
exit
service anomaly-detection ad0
exit
service external-product-interface
exit
service analysis-engine
virtual-sensor vs0
physical-interface GigabitEthernet0/1
exit
exit
IPS_5520_ERA#
2 RESPUESTAS
Emilio,
Te mando un saludo, me gustaría saber si ya has tratado lo siguiente:
1) Verificar si el módulo responde a pings desde la PC con IP 16.3.40.52
2) Habilitar telnet  en el IPS y verificar si puedes realizar un telnet al módulo desde el equipo 172.29.0.1 y desde 16.3.40.52. Esto con el fin de confirmar  que no exista un problema de conectividad entre estas redes.
3) Intentar desde otra computadora, tratar de abrir el IPS desde un browser y verificar si no se tiene un error de java.
4) Realizar un reset al módulo desde el ASA.
     hw-module module 1 reset
5) Verificar en el show module, que los servicios se encuentren arriba y el servicio de TLS Management esté en TRUE.
Gracias,
Itzcoatl Espinosa
Buenos días Itzcoatl,
te comento sobre las pruebas que sugieres:
1º - Llego por ping a la 172.29.0.2 desde la 16.3.40.52
2º - Telnet esta deshabilitado.¿Tendre que reiniciar el equipo si lo habilito? Lo digo porque el equipo esta en producción y deberia solicitar una ventana de actuación. Al intentarlo desde el ASA y desde mi pc esto es lo que obtengo:
ASA5520ERA# telnet 172.29.0.2
ERROR: % Invalid input detected at '^' marker
C:\Documents and Settings\pe2314>telnet 172.29.0.2
Conectándose a 172.29.0.2...No se puede abrir la conexión al host, en puerto 23:
3º - Tampoco he podido acceder a través de https desde otro pc así que prácticamente descarto un error de Java
4º - Con el reset al modulo me pasa igual; debería de solicitar una ventana de actuación. Aunque desactualizado, el equipo esta funcionando
5º- No consigo ver si el servicio TLS es TRUE. Adjunto un show module
ASA5520ERA#  sh module
Mod Card Type                                    Model              Serial No.
  0 ASA 5520 Adaptive Security Appliance         ASA5520            JMX1144L13M
  1 ASA 5500 Series Security Services Module-10  ASA-SSM-10         JAF113906X0
Mod MAC Address Range                 Hw Version   Fw Version   Sw Version
  0 001d.459f.b1e0 to 001d.459f.b1e4  2.0          1.0(11)2     8.0(4)39
  1 001d.451a.6592 to 001d.451a.6592  1.0          1.0(11)2     6.0(4)E1
Mod SSM Application Name           Status           SSM Application Version
  1 IPS                            Up               6.0(4)E1
Mod Status             Data Plane Status     Compatibility
  0 Up Sys             Not Applicable
  1 Up                 Up
6º He intentado implementar este comando sin éxito
IPS_METROVPN_ERA(config)# tls trusted-host ip-address 16.3.40.52 port 443
Error: getHostCertificate : socket connect failed [4,111]IPS_METROVPN_ARE(config)# tls trusted-host ip-address 16.3.40.52 port 443
Gracias por tu tiempo y ayuda
613
Visitas
ÚTIL
Respuestas
