cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Problema con VPN site to site
Hola buenas tardes
esperando se encuentres de lo mejor posible, les presento mi caso
estoy tratando de levantar una VPN Site to Site donde solamente tengo una ip Fija y la otra es Dinamica, ya habia levantado otras vpns pero entre dos direcciones de ip publicas fijas.
donde mis direcciones de cada subred son
Sucursal Remota:
192.168.230.0 /24
sitio cental:
192.168.220.0/24
esta es mi configuracion.
Del lado de la dinamico sucursal remota:
: Saved
ASA Version 8.2(1)
hostname 3mbremote
interface Ethernet0/0
nameif wan
security-level 0
ip address dhcp setroute
interface Ethernet0/1
nameif lan
security-level 100
ip address 192.168.230.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
duplex full
nameif management
security-level 100
management-only
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring 1 Sun Apr 2:00 last Sun Oct 2:00
dns domain-lookup lan
dns server-group DefaultDNS
name-server 208.67.222.222
name-server 8.8.8.8
object-group service DM_INLINE_SERVICE_1
service-object icmp
service-object icmp echo-reply
service-object icmp source-quench
service-object icmp time-exceeded
service-object icmp traceroute
service-object icmp unreachable
object-group icmp-type DM_INLINE_ICMP_1
icmp-object echo-reply
icmp-object information-request
icmp-object source-quench
icmp-object time-exceeded
icmp-object traceroute
access-list wan_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list ike extended permit udp any any eq isakmp
access-list lan_nat0_outbound extended permit ip 192.168.230.0 255.255.255.0 192.168.220.0 255.255.255.0
access-list wan_1_cryptomap extended permit icmp 192.168.230.0 255.255.255.0 192.168.220.0 255.255.255.0 object-group DM_INLINE_ICMP_1
pager lines 24
logging enable
logging asdm informational
mtu wan 1500
mtu lan 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (wan) 1 interface
global (lan) 1 interface
nat (lan) 0 access-list lan_nat0_outbound
nat (lan) 1 0.0.0.0 0.0.0.0
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.230.0 255.255.255.0 lan
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map wan_map 1 match address wan_1_cryptomap
crypto map wan_map 1 set pfs group1
crypto map wan_map 1 set peer < ip fija sitio central >
crypto map wan_map 1 set transform-set ESP-3DES-SHA
crypto map wan_map interface wan
crypto isakmp enable wan
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
ssh 192.168.230.0 255.255.255.0 lan
ssh timeout 20
ssh version 1
console timeout 0
dhcp-client broadcast-flag
dhcp-client client-id interface wan
dhcpd dns 8.8.8.8 208.67.222.222
dhcpd address 192.168.230.100-192.168.230.200 lan
dhcpd dns 8.8.8.8 208.67.222.222 interface lan
dhcpd enable lan
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group <ip fija sitio central> type ipsec-l2l
tunnel-group <ip fija sitio central> ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:08429c0f3db97294b503a6682b558841
: end
y la configuracion sitio Central es casi lo mismo solo que cambia
access-list lan_nat0_outbound extended permit ip 192.168.220.0 255.255.255.0 192.168.230.0 255.255.255.0
access-list wan_1_cryptomap extended permit icmp 192.168.220.0  255.255.255.0 192.168.230.0 255.255.255.0
pre-shared-key *
tunnel-group <ip sitio Remoto> type ipsec-l2l
tunnel-group <ip sitio Remoto> ipsec-attributes
pre-shared-key *
siguiendo los siguientes pasos:
isakmp policy 1 authentication pre
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash sha
isakmp policy 1 group 2
isakmp policy 1 lifetime 43200
isakmp enable wan
crypto ipsec transform-set vpn_3mb esp-3des esp-md5-hmac
host sitio Remoto
access-list Nombre_List extended permit ip 192.168.230.0 255.255.255.0 192.168.220.0 255.255.255.0
host sitio Central
access-list Nombre_List extended permit ip 192.168.220.0 255.255.255.0 192.168.230.0 255.255.255.0
tunnel-group <Ip fija sitio central> type ipsec-l2l
tunnel-group < ip fija sitio central> ipsec-attributes
pre-shared-key ********
crypto map Nombre_map 1 match address nombre_List
crypto map  Nombre_map 1 set peer < Ip fija sitio central>
crypto map Nombre_map 1 set transform-set Nombre_list
crypto map Nombre_map interface wan
y tambien lo inntente de manera con el Wizard pero no logro conectar la VPN.
espero me puedan ayudar. saludos.
Etiquetas (1)
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Re: Problema con VPN site to site
Buenas noches Oscar,
Como tu mencionas al tener un lado una IP dinamica la configuracion va a variar debido a que en un lado no sabes quien es el otro Peer.
La configuracion en el lado donde la IP es estatica es la que varia, Porque?
Porque el no sabe quien es el otro peer (se utiliza un dynamic crypto-map en vez de uno estatico)
Configuracion necesario en el sitio con la IP estatica (Central en tu caso)
crypto dynamic-map test 1 set transform-set
vpn_3mb
crypto map
Nombre_map_1 10 IPSec-isakmp dynamic test
crypto map Nombre_map_1 interface outside
  pre-shared-key
Lo prometido es deuda:
http://www.laguiadelnetworking.com/vptre-un-asa-con-una-ip-estatica-y-un-router-con-una-ip-dinamica/
Recuerda dejar tu comentario
Saludos,
Julio Carvajal Segura
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
8 RESPUESTAS
vpn_3mb
crypto map
  pre-shared-key
Saludos,
Muchas gracias, ahora en estos momento la levanto.
entonces como tu me indicas unico que se necesita del lado del sitio central donde se encuentra la ip fija es
hacer un crypto dynamic-map con lo que me dijiste.
en tu post en tu blog, dice que no se necesita realizar un ACL en mi caso tambien?
saludos.
Correcto,
No se requiere del lado donde esta la IP estatica,
Me cuentas como te va
For Networking Posts check my blog at http://www.laguiadelnetworking.com
Cheers,
Ahorita ya no me dejaron probar, para realizar la VPN pero encuanto lo pueda hacer te lo are saber Julio muchas gracias.
por otro lado me surge una pregunta sobre la version 8.2, habra una manera para realizar una apertura de un rango de puertos por nat estatico?
lo ocupo para la VoiP RTP 10000-20000 UDP ya que no se escucha la voz del otro lado del telefono, pero ami si me escuchan.
tengo el access list
access-list 101 extended permit udp any interface wan range 10000 20000 , pero eso es para la entrada
y para la salida no me deja poner un rango especifico, tengo un object service telefonia udp 10000 20000
pero cuando intento hacer el nat estatico donde 192.168.230.121 es mi servidor de telefonia
static (lan,wan) udp interface telefonia 192.168.230.121 telefonia netmask 255.255.255.255
no me deja y asi eh intentado ponerlo manualmente los puertos y no me deja publicar ese servidor NAT por un rango de puertos.
eh leido que es por la version de firmware que tengo es la 8.2 y eso se puede realizar apartir de la 8.3 eso es cierto?.
saludos.
Oscar,
Muchas gracias por tu pregunta, te pedimos calificar la respuesta y dejarnos saber si la pregunta fue respondida, esto es para ayudar a Julio Carvajal en su rating.
Gracias de antemano.
Saludos cordiales.
Moderador CSCe.
NO le puedo dar correcta respuesta ya que no se ah solucionado mi primer problema y con respecto al segundo caso de que necesito nat un rango de puertos hacia un servidor host de telefonia que tengo dentro de mi red privada, sabes algo al respeto?
estoy siguiendo estos pasos:
object network elastix
host 192.168.230.5
object service RTPS
service udp source range 10000 40000
nat(lan,wan) source elastix interface udp service RTPS RTPS
y me marca ERROR: NAT unable to reserve ports
alguna idea del por que aparece esto??
saludos
Este post, es para el problema con VPN.
En el otro hablaremos acerca del NAT
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
perfecto
entonces nos pasamos al otro post. y sobre la VPN es levantarla cuando me den chansa.
muchas gracias Julio ya mire tmb el post que publicaste y de ahi me guiare.
saludos.
1179
Visitas
ÚTIL
8
Respuestas
