04-06-2006 07:38 AM
I was hoping to run 6500 in Native Mode (12.2(18)SD5,7 SXF) i.e IOS on both SP and RP.
I have no idea what way the box is configured regarding whether Hybrid (CatOS on SP/PFC, IOS on MSFC) or Native at present.
Those later IOS images are approx. 75M.
From what I can see on CCO, Sup720 comes with 512MB DRAM and 64Mb bootflash on both SP and RP.
Does this mean we need a Compact Flash card to run such an image?
Mark
04-06-2006 08:14 AM
Mark,
You are correct, 12.2(18)SXE and later releases will not fit on the onboard flash and you will need to equip your Sup720 with a compact flash card.
From personal experience, I recommend that you run 12.2(18)SXF1 or better.
Hope this helps. If so, please rate this post.
Brad
04-06-2006 11:26 PM
Brad,
Thanks for the reply.
So in order to run 12.2(18)SXF1 or similar I would need at least MEM-C6K-CPTFL128M? :(
Mark
04-07-2006 02:29 AM
Hi Mark,
Yes you are very right with the part number.
MEM-C6K-CPTFL128M is a CompactFlash Type II device which can be used to load sup 720 integrated image.
By default the cat6k with sup 720 will come up with catos and if you want to convert to native ios you can have a look at this link also
http://www.cisco.com/warp/customer/473/81.html#conv_720
HTH, if yes please rate the post.
Ankur
04-07-2006 04:49 AM
Thanks for that Ankur.
So Cat6k's being shipped at present come with CatOS on SP/PFC and IOS on MSFC?
Is there a link that states that?
Mark
04-07-2006 07:41 AM
"So Cat6k's being shipped at present come with CatOS on SP/PFC and IOS on MSFC?"
Im afraid this is not true at all. The Sup720 only runs Native IOS. The version of Native IOS you receive is based on your selection when you order the switch.
If you look at the IOS Upgrade Planner you will see that only Native IOS images are available for download.
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi
Please rate all helpful posts.
Brad
04-10-2006 12:18 AM
So there are images that fit on 64MB SP bootflash?
Mark
04-11-2006 10:23 PM
Hi Brad,
SUP720 can 100% run CATOS and there is no doubt for that matter.
The Catalyst 6500 series Supervisor Engine 720 ships with 512-MB DRAM, which fully supports software release 8.x
The Catalyst 6500 series Supervisor Engine 720 ships with a 64-MB bootflash device
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm#wp20785
MARK if you talk of catos yes it will support in 64 MB bootflash and there are some images in NTAIVE IOS which will be working with 64 MB SP bootflash though some Supervisor Engine 720 Release 12.2SX images are larger than the bootflash device and must be stored on a CompactFlash card.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm#wp2560955
Ankur
06-06-2006 09:14 AM
Can we use ftp to boot the IOS image (that is greater than what the onboard 64MB can hold)? In this sense, we do not need to purchase the CompactFlash card.
06-09-2006 10:04 AM
If you're going to be using any QoS, please save yourself the pain of 12.2(18)SFX-SFX3 and go directly to SFX4. If you're doing VoIP cram as much memory in as you can afford and QoS by vlan.
06-26-2006 10:35 PM
Just my ten pence worth -
1) Cat6k with Sup720s seem to be shipped with native IOS at the momeent - I received a pair this week that were shipped with 12.2(17), on the internal 64Mb flash.
2) I ordered a 512Mb compact flash (MEM-C6K-CPTFL512M
) with it - I'd recommend this as I wanted to first load the 70+ Mb 12.2(18)SXF4 image, then use the software modularity install so I knew I'd need more space...
Hope this helps...
07-21-2006 11:48 AM
Cisco ships Cat6k / Sup720 or Sup32 with native IOS preinstalled for the past year or so. Sup720 supports CATOS and Native (8.3(2) and higher/12.2(17d)SXB1 and higher)
