Catalyst 4003 : both layer 3-module(4232rj45) AND GBIC 18port-module in same chassis possible ?
Is it possible to install layer3-module
AND 18port GBit GBIC-module in the same chassis of catalyst 4003 ???
Does the layer 3 module have appletalk routing capabilities ???
1 REPLY
Anonymous
N/A
Re: Catalyst 4003 : both layer 3-module(4232rj45) AND GBIC 18por
yes, you can have both in the same chassis.
The l3 module has the appletalk routing capability if you run 12.0(10)W5(18f) ioS On the layer3 module.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/78_10853.htm
174
