CPA Vs 3745 (XCA and Lan token-ring virtual)
In my new architecture network, I will use the function of the lan
Token Ring to establish connections sscp-to-sscp. In my case I have 14
MVS which dialogues today via a 3746/9x0, how I must code node XCA of
a partition which must communicate with the 13 other partitions.
Below you have the definition of node XCA, with the subareas and their
addresses Token Ring concerned. This correct like definition is
INSXCA00 VBUILD TYPE=XCA
PORTBA36 PORT ADAPNO=0,CUADDR=BA36,MEDIUM=RING,TIMER=20
GSNABA36 GROUP DIAL=YES,ANSWER=ON,DYNPU=YES,AUTOGEN=(5,L,P), CALL=INOUT
GINSRE13 GROUP DIAL=NO
IINSRE12 LINE USER=SNA,ISTATUS=ACTIVE
NINSRE12 PU MACADDR=400000000003, +
TGN=1, +
SAPADDR=04, +
SUBAREA=1, +
PUTYPE=5, +
ISTATUS=ACTIVE
IINSRE13 LINE USER=SNA,ISTATUS=ACTIVE
NINSRE13 PU MACADDR=400000000004, +
TGN=1, +
SAPADDR=04, +
SUBAREA=3, +
PUTYPE=5, +
ISTATUS=ACTIVE
Silver
Re: CPA Vs 3745 (XCA and Lan token-ring virtual)
I am not sure if I understand your question. I think that you already knew the answer. You have to define a similar section for each MVS:
TGN=1, +
SAPADDR=04, +
SUBAREA=1, +
PUTYPE=5, +
ISTATUS=ACTIVE
Of course, you have to modify the macro, the MACADDR value, SUBAREA value, and possibly SAPADDR.
One more comment. The major difference between XCA and 3746 on SSCP-SSCP connection is that XCA does not provide network boundary function. Thus, all 14 MVS must have an unique subarea number.
Francis
164
