07-03-2002 01:46 PM
Can I use a MSFC from a Catalyst 6509 on a Catalyst 4004?
07-03-2002 01:46 PM
4004?
MSFC is not supported on Catalyst 4000 family
07-05-2002 05:04 PM
If you are looking for Layer 3 module for CAT4006, we have WS-X4232-L3 module.This takes up a slot but also provides 32 10/100 switched ports and 2 routed gig ports
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/gmdcf_nt.htm#xtocid20
If you have a CAT4006, you might also want to look at the SupIII which has built in layer 3 functions and runs IOS
http://www.cisco.com/warp/public/cc/pd/si/casi/ca4000/prodlit/4kse3_qp.htm
