Community Member
Does nexus-1000v.4.2.1.SV2.1.1a.1010.ova is a N1010 running in a VM ?
I downloaded Nexus1000v.4.2.1.SV2.1.1a.zip form Cisco website, and uncompressed it in a folder named Nexus1000v.4.2.1.SV2.1.1a.
I was looking for VSM .OVA files, and I found il in the folder Nexus1000v.4.2.1.SV2.1.1a\VSM\Install.
But, I also found nexus-1000v.4.2.1.SV2.1.1a.1010.ova in that directory.
Is it a N1010 running in a VM ?  If so, il would be very cool since N1010 supports different kinds of VSB (VSM, VSG, NAM, ...).  But when I tried to install it on VMware, I obtained this error message:
"An error occured while reading: OVA has invalid header block (checksum error)"
I tried with version Nexus1000v.4.2.1.SV2.2.1, same error.
Does that file in intended to run on VMware ?  What this file is intended for ?
Thank you very much.
You cannot run a 1010 on a VMWARE machine.
A 1010 is physical appliance.
Please check the following for installation guidance:
http://www.cisco.com/en/US/products/ps9902/prod_installation_guides_list.html
I hope this helps.
Carlos
Community Member
Re: Does nexus-1000v.4.2.1.SV2.1.1a.1010.ova is a N1010 running
INTERESTING....could you inform Cisco of this calo?
From the readme below, I don't think they know.
Cisco Nexus 1000V Virtual Security Gateway Version 4.2(1)VSG2(1.1) for VMware vSphere 4.1 +
This folder contains the Nexus 1000V Virtual SSecurity Gateway(VSG), Schema for XML APIs, the README and the Cisco NX-OS Licensing and Copyright document.
VSG:
1. Install
    i)   ISO - nexus-1000v.VSG2.1.1.iso            (md5 709e3b924aeca72bfe2079f995a49707)
    ii)  OVA - nexus-1000v.VSG2.1.1.ova            (md5 b6e49a377172041495418ff46bc0cd3a)
    iii) 1010 OVA - nexus-1000v.VSG2.1.1.1010.ova  (md5 64c77fb3bf2c8031ac0b8cff3cf420b2)
2. Upgrade
    i)  Kickstart: nexus-1000v-kickstart.VSG2.1.1.bin (md5 eee74b7b7bc03cafbd847656cf381cc1)
    ii) System:    nexus-1000v.VSG2.1.1.bin           (md5 fefd8b59cb8d58ca5bfe87a75f4c95e2)
3. VNMC-PA
    i) VSG PA: vnmc-vsgpa.2.1.1b.bin (md5 8b9aee4ce4918bab21715068af1be423)
The VSG is supported on VMware vSphere 4.1+ Systems.
ISO:
ISO format can be used to install the Nexus1000V VSG on a user created VSG VM. This can be used on VMware vSphere 4.1+ Systems.
OVA:
The OVA file can be used to deploy the Nexus1000V VSG VM appliance. This can be used only on VMware vSphere 4.1+ Systems.
Shesh
1394
