How do I remove the Serial Interface and Controller T1 entries from the configuration when using a PA-MC-4T1
I cant seem to remove the int se1/2:2 from the config. I have a PA-MC-4T1 card configured for T1 service. Below is what is left in the config.
controller T1 1/2
framing esf
linecode b8zs
channel-group 2 timeslots 1-24
controller T1 1/3
framing esf
linecode b8zs
channel-group 3 timeslots 1-24
interface Serial1/2:2
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
encapsulation frame-relay IETF
shutdown
no fair-queue
interface Serial1/3:3
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
frame-relay lmi-type ansi
1 REPLY
Anonymous
N/A
Re: How do I remove the Serial Interface and Controller T1 entri
As long as you have the command
"channel-group 2 timeslots 1-24"
under the controller T1 1/2, that
serial interface will exist. You
can't manually delete it, you would
need to remove/change the channel-
group command.
271
