Community Member
IGESM in IBM blade center
Hi all,
Is anybody knows how to get telnet access to IGESM in IBM blade servers?
basically i need to enable trunking between this module and uplink switch.
Thanx in advance.
Rajesh
Community Member
Re: IGESM in IBM blade center
You need to enable the external management from the management module.
Here you'll find the user guide for IGESM switch :
http://www.redbooks.ibm.com/redpapers/pdfs/redp3869.pdf
Pages 55 and 248 might interest you!
Please rate if this helps.
Christophe
Silver
The three OEM blade server switches for HP,IBM, and now Dell are a joy to work with...not.
With the IBM series please be sure that you notate what version of code is running on it and keep track of it because its the minimum version it supports. You put a earlier version on it, reboot, and you'll get a nice four port brick.
Community Member
I think, if you know the ip address of the management module and if access is there you can access.
Else connect a console cable to the management console port and access the same.
You need to understand the bladecenter cisco n/w architectuer before you you try your hand.
good luck.
Community Member
Here is a good Cisco IBM Blade Design Guide for your reference.
247
