Nexus 1000v Layer3 Control not coming up
For info, I run 4.2(1)SV1(4) as a VM and not the appliance.
I tried this morning to migrate a small environment to the Nexus L3 control instead of L2 for a certain requirement. We have two ESX in the with the Nexus 1000v running sucessfully for months on L2.
I tried to follow the procedure that is in this document. I followed this script:
Created a layer3 control0 interface with an IP in vlan951.
So I had my VMWare guy move a VMKernel interface of each ESX host to this profile:
port-profile type vethernet VLAN951
  vmware port-group VLAN951
  capability l3control
  switchport mode access
  switchport access vlan 951
  system vlan 951
  no shutdown
  state enabled
Then modified the svs domain like such:
svs-domain
no control vlan
no packet vlan
svs mode 13 interface control0
I made sure that I have layer-2 connectivity between the VSM host and the rest ESX hosts is OK, but I am not certain how you actually assign a layer 2 vlan to the control0 interface... Is it supposed to broadcast on all the VLANs? Or is it a correlation of the port-profile config and svs-domain that does that?
In any case, my two VEM go down and do not come back up once I am in l3 mode. I had to revert back to L2.
Simon T.
1 REPLY
Hi Simon,
Since you are using ctrl0 as the layer 3 interface, you need to assign the IP address under the ctrl0 interface (interface ctrl0). This IP address should be able to communicate with the vmk interface's IP address.
Shankar
673
