Nexus 5548 PFC issue
Hello, I'm having a strange problem with PFC. I have a server that has a QLogic 8142 dual port CNA and one port is connected to NexusA and the other to NexusB. DCBX negotiation succeeded and no-drop is set for CoS 3. The TLV on both Nexus and both card ports match up and they seem to be in agreement...
However, PFC gets applied to all CoS evenly for some reason on the CNA and it really wrecks throughput. At first we just thought it was a NIC issue because the retransmission rate gets up to 300% when I/O heavy stuff like backups are happening. The odd thing though, was that there were never any errors or collisions reported. Finally I look at the traffic coming into the CNA and this is what I see:
Receive Broadcast Packets          141675248
Receive CBFC Pause Frames 0          73150267
Receive CBFC Pause Frames 1          73150267
Receive CBFC Pause Frames 2          73150267
Receive CBFC Pause Frames 3          73150267
Receive CBFC Pause Frames 4          73150267
Receive CBFC Pause Frames 5          73150267
Receive CBFC Pause Frames 6          73150267
Receive CBFC Pause Frames 7          73150267
Receive Control Packets          73150267
Receive FCoE Packets          1128698130
Receive Jabber Packets          0
Receive Mgmt Packets          585890
Receive Multicast Packets          1854877772
Receive Octets          4661675314982
Receive Octets Ok          4656993697750
Receive Oversize Packets          0
Receive Packets          20478644522
Receive Packets 1024to1518Octets          854370673
Receive Packets 128to255Octets          10293526277
Receive Packets 1519toMaxOctets          128131115
Receive Packets 256to511Octets          170181538
Receive Packets 512to1023Octets          154389360
Receive Packets 64Octets          78297449
Receive Packets 65to127Octets          8799748110
Receive Packets Discarded Priority 0          1923
Receive Packets Discarded Priority 1          0
Receive Packets Discarded Priority 2          0
Receive Packets Discarded Priority 3          0
Receive Packets Discarded Priority 4          0
Receive Packets Discarded Priority 5          0
Receive Packets Discarded Priority 6          0
Receive Packets Discarded Priority 7          0
Receive Packets Ok          20405494253
Receive Packets Priority 0          19225451771
Receive Packets Priority 1          0
Receive Packets Priority 2          0
Receive Packets Priority 3          1128698132
Receive Packets Priority 4          584
Receive Packets Priority 5          12099267
Receive Packets Priority 6          12033228
Receive Packets Priority 7          8810261
Receive Pause Packets          0
Receive Undersize FCS error Packets          0
Receive Undersize Packets          0
Receive Unicast Packets          18408941233
Transmit Broadcast Packets          651143
As you can see the CBFC pause frames are applying to all priorities which effectively means my link is pausing like standard flowcontrol is on but I can't find much of anything on the switch that would point me in the right direction. I'm hoping a second set of eyes might be able to point me in the right direction.
The policies on both switches are:
class-map type qos class-fcoe
class-map type qos match-any class-default
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-default
  match qos-group 0
policy-map type qos default-in-policy
  class class-fcoe
    set qos-group 1
  class class-default
    set qos-group 0
policy-map type queuing default-in-policy
  class type queuing class-fcoe
  class type queuing class-default
policy-map type queuing default-out-policy
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-default
  match qos-group 0
policy-map type network-qos jumbo
  class type network-qos class-fcoe
    pause no-drop
    mtu 2158
  class type network-qos class-default
    mtu 9216
system qos
  service-policy type queuing input default-in-policy
  service-policy type queuing output default-out-policy
  service-policy type qos input default-in-policy
  service-policy type network-qos jumbo
  fex queue-limit
Interface configuration (same on both - and I'm thinking the fact that the FCoE VLAN (1070) is the same on both and that LACP is active may be an issue...):
interface Ethernet1/29
  description ORACLE
  switchport mode trunk
  switchport trunk allowed vlan 111,1070
  channel-group 149 mode active
Port Channel info:
SwitchA:
port-channel149 is up
vPC Status: Up, vPC number: 149
  Hardware: Port-Channel, address: 0005.9b72.0ce4 (bia 0005.9b72.0ce4)
  Description: ORACLE
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/29
  30 seconds input rate 3343488 bits/sec, 417936 bytes/sec, 254 packets/sec
  30 seconds output rate 4113880 bits/sec, 514235 bytes/sec, 1993 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 3.82 Mbps, 227 pps; output rate 4.43 Mbps, 2.04 Kpps
  RX
    3458452690 unicast packets  1164669 multicast packets  650875 broadcast packets
    3460268234 input packets  5922693717615 bytes
    2696809069 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    18407152373 unicast packets  1924699542 multicast packets  141651327 broadcast packets
    20473503242 output packets  4660392023519 bytes
    370065327 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    73139330 Tx pause
  6 interface resets
SwitchB
  Hardware: Port-Channel, address: 547f.eedd.9d64 (bia 547f.eedd.9d64)
  Description: ORACLE
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  30 seconds input rate 3702752 bits/sec, 282 packets/sec
  30 seconds output rate 638704 bits/sec, 162 packets/sec
    input rate 3.82 Mbps, 241 pps; output rate 163.26 Kbps, 88 pps
  RX
    3501912802 unicast packets  1169034 multicast packets  196916 broadcast packets
    3503278752 input packets  5936848468592 bytes
    2698117037 jumbo packets  0 storm suppression packets
    0 Rx pause
  TX
    1233207065 unicast packets  100406251 multicast packets  16368627 broadcast packets
    1349981943 output packets  435290532701 bytes
    165671680 jumbo packets
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  7 interface resets
I think the odd thing here is that only SwitchA seems to transmit any pause. As you can see here on SwitchA, the pause count for the port-channel, the interface in priority-flow-control and in flowcontrol are all incrementing at the same pace. I was told that flowcontrol incrementing at the same pace as PFC was just a bug, but now I'm not really sure because this doesn't happen at all on SwitchB. The Pause count on SwitchA increments at the same pace as the CBFC frames on the CNA. However SwitchB has PFC pause counters but they don't match at all.
SwitchA PFC:
Ethernet1/29       Auto On  (8)       0          73139266
SwitchB PFC (I don't even know how to account for the different numbers because this output was gathered before the CNA and the CNA matches only SwitchA):
Ethernet1/29       Auto On  (8)       0          79050794
SwitchA Flowcontrol (increments at the same pace as PFC)
Eth1/29      off      off      off      off         0                 73139296
SwitchB Flowcontrol (Stays at 0)
Eth1/29      off      off      off      off         0                 0
Thanks for taking a look.
434
