06-22-2012 06:39 AM
Hi all,
I have 2 N5K with 2 N2K configured like that
I am using the latest version 5.1(3)N2(1a)
When I created a port-channel on n5K I didn't have any problem, now when I created an other port-channel on the nexus 2k with the same configuration I have the message
port not compatible [slot in VPC A-A mode)
When I read the document this kind of configuration is supported , do I need to configure something else or to activate an other feature ?
thanks
Eric
06-22-2012 06:47 AM
Hi Eric
Yes, this topology is supported. Its called Enhanced VPC. When you build a port channel from n2k towards the server, do not include the 'vpc x' configuration under the port channel and it should work.
This is documented in our EVPC configuration guide at
Thanks, Vinayak
07-19-2012 07:58 AM
Hello Eric,
I meet the same issue. Did you find a solve ?
many thx in advance.
Nicolas.
07-20-2012 01:02 AM
Update:
I'm sorry, did not carefully read the answer from Vinayak Sudame
- "do not include the 'vpc x' configuration under the port channel and it should work"
In his reply, it's all said right
I do not quite clearly understood your situation, perhaps, as I understand you are trying to configure a Po2(channel to Server) as vPC channel?
Since you have a dual-home FEX configuration you need to configure Po2 as a standard etherchannel configuration on both switch:
interface e101/1-2
channel-group 2 mode active
interface e102/1-2
interface port-channel2
description Server
It is important to keep these configs identical on both switches! So I recommend doing this through switch-profile...
Look for a very good example http://nexusfu.blogspot.com/search/label/vpc
Finally, you should have, according to your schema, something like this:
interface port-channel101
description FEX 101
switchport mode fex-fabric
fex associate 101
vpc 101
interface port-channel102
description FEX 102
fex associate 102
vpc 102
interface e1/3-4
fex associate 101
channel-group 101
interface e1/5-6
fex associate 102
channel-group 102
interface e101/1-2
interface e102/1-2
description Server
12-30-2013 05:05 PM
Thank you, I had the same problem, and removing the vpc from the port-channel interface fixed it for me!
Chris.
01-04-2014 02:03 AM
What model do you mean by 'N5K'? Enhanced vPC and this topology is not supported by Nexus 5010 and 5020, only by 55xx.
